Posté le: 29.08.2018, 09:48:03 Sujet du message: dynamomètre de châssis (dyno) qui mesure
Ceci est un dynamomètre de châssis (dyno) qui mesure le tr/min, kv, la tension, le courant dessine(tire), le pouvoir(la puissance) et la production de moment de torsion de votre véhicule. Ce dyno est le grand(super) outil pour l'analyse du moteur, ESC (l'augmentation)..
his is a chassis dynamometer (dyno) that measures the rpm, kv, voltage, current draw, power and torque output of your vehicle. This dyno is great tool for motor analysis, ESC (boost) adjustment, brushless sensor adjustment, gearing calculation, tire selections, and much more. The dyno is coupled with to a knurled roller via a pulley and belt to accelerate the inertial mass. We will call this a ‘flywheel’ for simplicity. Our electronic board takes the flywheel’s inertia (resistance of an object to a change in its state of motion), measures the rate it takes to accelerate and calculates the output power and torque of your vehicle. Our dyno repeatedly measures and calculates power in small increments to produce an accurate graph on a PC of the engine’s power characteristics.
Our dyno is suitable for 1/12, 1/10, and 1/8 gas or electric vehicles. It incorporates an adjustable wheelbase design for up-to 370mm of allowable wheelbase; and 375mm of vehicle width.
TECHNICAL SPECIFICATIONS
Torque: 2N/m Max (with GT2 2mm Belt)
RPM: 100K Max
Units: English & Metric
Adjustable Reading and Logging Rate: Up to 50Hz
PACKAGE CONTENTS
A. For Chassis Dyno with Flywheel Unit:
(1) R/C chassis dyno with customer's selected flywheel unit
(1) 50V/180A Voltage and current
(1) Dyno electronic board v1.1
(1) Micro-B USB cable
B. For Chassis Dyno without Flywheel Unit:
(1) R/C chassis dyno kit
(1) Necessary components to attach your existing Motor Dyno Flywheel Unit
Please note that you need flywheel unit to use this kit. No electronics are included.
SUPPORTED OPERATING SYSTEMS
Microsoft Windows 7, 8, 10
TOOLS REQUIRED
Allen: 1.5mm, 2.0mm
Phillips Screw Driver
Soldering Iron
EQUIPMENT REQUIRED
Electronic Speed Controller (ESC)
Battery to Power ESC and Motor.
R/C Transmitter and Receiver Or Servo Tester
(Not Required if using ESC Throttle Controller Board)
Windows PC with 1 USB Port
(Two USB ports are required when using the ESC Throttle Controller Sensor)
DOWNLOADS
Instructions Guide, Software, and Drivers please go to our Download Page
** Please check our Knowledge Base to find useful information about all of our products. **
