Blue backlit LCD, 16 x 2
Microprocessor controlled
Includes HCT and MiniJST charge connectors
Integrated JSTXH 2 and 3 cell balance ports
Temperature controlled fan
2 button Safe Start
Specifications
Input voltage: 100 240V, 50 60Hz AC or 12 15V DC
Max. power: 50W
NiMH / NiCd: 1 8 cells
LiPo / LiFe: 2 3S
Charge current: 0.1 6.0A
Balance Connectors: JSTXH 2S 3S
Dimensions: 161 x 105 x 60mm
Weight: 350g
Safe Start
Safe Start Technology ensures a proper charge mode and a safe charge current are used for each charge cycle and battery. The charger will not allow charging of LiPo batteries without Safe Peak balancing, nor will it allow you to accidentally charge a NiMH battery in LiPo mode. To keep your batteries from being charged incorrectly, the charge initiation wizard walks you through the process of setting the parameters every time.
Safe Peak
Safe Peak Technology optimizes the charging modes for each battery. NiCd and NiMH batteries are charged to their maximum performance voltage by optimizing the delta-peak for each battery, thus helping preserve battery life. LiPo and LiIon batteries are balance charged to within 0.05V per cell, thus helping prevent the catastrophic failures often seen with other technology.
The Ascend Story
The Radient Ascend Multi-Chemistry charger is an innovation in entry-level R/C battery chargers that focuses on simplicity, capability, and safety. With our Safe Start charge initiation wizard and built-in connection analysis, the possibility of starting a charge in the wrong mode has been virtually eliminated. With Safe Peak, the Ascend will charge batteries in capacity or current mode up to 6 Amps, giving you the options you need while ensuring your batteries reach their maximum power potential. The backlit LCD screen makes it easy to select all of your charge parameters while also monitoring your battery’s status in any light. No other charger combines the simplicity of AC or DC input with LCD display, multi-chemistry capability, and safety of charging LiPo batteries with such style and affordability.
