Posté le: 25.09.2016, 17:53:04 Sujet du message: Chargeur Hitec X4 AC Pro AC/DC 4 Ports Multicharger
Product Description
Building on the popularity of our X4 AC Plus, we decided to take it up a notch with the introduction of our X4 AC Pro high-performance, microprocessor-controlled charger/discharger with extensive battery management capabilities. Capable of operating on 100 - 240 volts AC household current or from an 11 - 18 volts DC power source, this new multi-faceted powerhouse exudes a total charge circuit power of 200 watts with Power Distribution capability in AC mode and a 300-watt output when in DC mode. The X4 AC Pro allows you to connect up to four batteries of varying chemistries (NiMH/NiCd/LiPo/LiFe/Lilon/LiHV/Pb) to any of the charging channels with each channel performing independently of one another. Additional features include our “Charge Master” software, providing the unprecedented ability to operate your charger via your personal computer plus a built-in Bluetooth for Smartphone app operation. Experience the future of charging with Hitec!
Charging Specifications:
AC Input: 100 - 240 Volts AC
DC Input: 11 - 18 Volts DC
Total Charge Circuit Power on AC Power: 200 Watts with Power Distribution
AC Power Distribution
Channels A & C: 100 Watts Total
Channels B & C: 100 Watts Total
Power Distribution Adjustable Range
Channels A & B: 50 - 100 Watts
Channels C & D: 0 - 50 Watts
Total Charge Circuit Power on DC Power:
300 Watts Total Power
Channels A & B: 100 Watts each / Channels C & D 50 Watts each
Charge Current
Channels A & B: 0.1 - 10.0 Amps
Channels C & D: 0.1 - 5.0 Amps
Discharge Wattage: 10 Watts per Channel
Discharge Current: 0.1 - 2.0 Amps per Channel
Discharge Current for Lithium Battery Balance: 200 mAh
LiPo, LiHV, LiFe and LiIon Cell Count: 1 - 6 cells
NiMH / NiCd Cell Count: 1 - 15 cells
Pb / Lead Acid Voltage Range: 2 - 20 VDC
Battery Capacity Range: 100 - 50,000 mAh
Auxillary Output: 5 Volt 2.1 Amp DC USB Device Charge Port
Communication Methods
USB Port for PC Control & Firmware Upgrades
Bluetooth 4.0 for Smartphone Apps
Dimensions: 3.8 x 7.2 x 2.8 in / 97 x 182 x 71mm
Weight: 47 oz / 1335g
