Posté le: 14.08.2016, 17:51:06 Sujet du message: chargeur Hexfly HX-403 Dual Port 2S, 3S, 4S AC/DC LiPo LiFe
chargeur Hexfly HX-403 Dual Port 2S, 3S, 4S AC/DC LiPo LiFe Battery Charger
Your HX-403:
The Hexfly HX-403 charger is an easy to use multifunctional charger with built in LiPo balancing for 2S - 4S LiPo or LiFe batteries. You can charge two 2S batteries at the same time or one 3S or 4S batteries.
With built in power supply, the HX-403 is an all in one package at a price that is hard to beat.
Specifications:
Input Voltage - AC 100~240V / DC 10~18V
Current Rate Range - 0~3.0A
Support for Charging - 2s*2/3s/4s (cells)
Support JST-HX 2.5 Connector
Features:
Detect current rate and capacity of individual cell
Identify the Cell Count Automatically
Auto Charger and Auto Cut-Off for Safety
Teperature Protection Fuction. Adjust Charge Power Automatically when Overheat
