The RDX1 is an AC/DC ultra-performance microprocessor-controlled battery charger/discharger with management features suitable for all popular chemistries. Its sleek tower design allows easy front-loading plug-in convenience of balancing and temperature sensor ports, a USB link and USB 5VDC 2.1 amps and 4mm battery sockets. Deluxe features include a 3.2-inch easy-to-read LCD screen and our Charge Master software which allows the unparalleled ability to operate the RDX1 through the computer. This compact, 60-watt wonder brings integrated balancing, convenience and ease to all your charging operations.
Features
Optimized Operating Software
10 Battery Memory
Internal Lithium Battery Balancer
Multiple Lithium Battery Charge Modes
Works with Hitec's Charge Master Software
LiPo Battery Meter
Slim In-line Design Saves Valuable Space
Charging Specifications
AC Input Voltage: 100-240V
DC Input: 11-18V
Charge Power: 60W
Charge Current Range: 0.1 - 6.0A
Max. Discharge Power: 5W
Discharge Current Range: 0.1 - 2.0A
Balancing Port Current Drain: 200MA/Cell
NiCd/NiMH Battery Cell Count: 1-15 Cells
LiPo/LiHV/LiFe/LiIon Cell Count: 1 - 6 Cells
Pb Battery Voltage: 2 - 20V
Net Weight: 470g
Dimensions: 159 x 72.5 x 123mm
AC/DC Chargers
Power Peak D7 AC/DC Charging Station
X4 AC Plus 4 Port AC/DC Multi-Charger
X4 Micro AC/DC 1-Cell LiPo Charger
X2 AC Pro 2 Port AC/DC Multi-Charger
X2 AC Plus 2 Port AC/DC Multi-Charger
RDX1 AC/DC Battery Charger/Discharger
X1 mini – AC Input Balance Charger/Discharger
X1 Touch 55-Watt, AC/DC, Multi-Chemistry, Touch Screen, Battery Charger
X1 AC Plus Single Port AC/DC Charger
X1 MF 80-Watt, Multi-Function, AC/DC Charger
