RCmag :: Voir le sujet - Chargeur Traxxas EZ-Peak™ Plus LiPo-Compatible Balance Char
philippe27
MessagePosté le: 10.12.2011, 14:40:13    Sujet du message: Chargeur Traxxas EZ-Peak™ Plus LiPo-Compatible Balance Char Répondre en citant
Chargeur Traxxas EZ-Peak™ Plus LiPo-Compatible Balance Charger
Charge Two Packs at Once!
Optional Dual Charging Adapter for EZ-Peak Plus
EZ-Peak Plus is ready for 2S-6S LiPo charging right out of the box. Add the optional Dual Charging Adapter, and you can charge two LiPo packs at the same time, with full balance-charging capability. Just plug your identical 2S or 3S packs into the Adapter (#2917 for 2S packs, #2918 for 3S), select the EZ-Peak Plus' Balance Charge mode, and you're ready to charge both packs at once. Be sure to read all instructions and cautions included with the Dual Charging Adapter before charging your LiPo batteries. The Dual Charging Adapter is for use with Traxxas Power Cell LiPo batteries only.
Z-PEAK PLUS (#2933) SPECIFICATIONS
AC Input: ­ 100–240 Volts
DC Input: ­ 11–18 Volts
Charge Current Range: ­ 0.1–6.0A (80W Max.)
Discharge Current Range: ­ 0.1–2.0A (10W Max.)
Current Drain For Balancing Port: ­ 300mA/cell
NiCd/NiMH Battery Cell Count: ­ 1–15 Cells
LiPo/LiFe/Lilon Cell Count: ­ 1–6 Cells
Pb Battery Voltage: ­ 2–20V
Net Weight: ­ 490g
Dimensions: ­ 135 x 112 x 60.9mm
MODEL 2933: Traxxas EZ-Peak Plus Programmable LiPo / LiIon / LiFe / NiMH / NiCd / Pb Charger
with included 2S-6S balance adapter, and Traxxas/Molex/receiver charge leads.
http://traxxas.com/products/parts/chargers/2933ezpeakchargerplus6amp
http://traxxas.com/sites/default/files/2933-EZ-Peak-Plus-Manual-111106.pdf
