RCmag :: Voir le sujet - News Chargeur muchmore racing MM-HBPB Hybrid PRO AC/DC Balan
philippe27
MessagePosté le: 01.12.2011, 09:37:29    Sujet du message: News Chargeur muchmore racing MM-HBPB Hybrid PRO AC/DC Balan Répondre en citant
News Chargeur muchmore racing MM-HBPB Hybrid PRO AC/DC Balance Charger/Discharger & 24A Power Supply
SPECIFICATIONS
★ All in one design
★ Microprocessor controlled
★ 2 kinds of charge cutoff system : Peak cut(Lithium Voltcut), temperature cut
★ Blue back light LCD display with 16x2 characters
★ 10A charging and 5A discharging with high capacity LiPo,LiFe batteries
★ Individual voltage balancer for Lithium batteries inside
★ Real time individual voltage monitoring (charging and discharging for Lithium batteries)
★ Normal , Storage, Balance charge mode for Lithium batteries
★ Delta-peak sensitivity(NiMh, NiCd)
★ Time limit function
★ Input voltage monitoring
★ Data storage(store up to 5 packs in memory)
★ Micro temp sensor
FEATURES
Dimensions : 142 x 119 x 141mm
Weight : 1300g
NiCd,NiMh No. of cells : 1~18
LiPo,LiFe,Lilo No. of cells : 1~6
Pb Battery voltage : 2~24V
Charge current : 0.1~10.0A(adjustable) *Max 200Watt
Discharge current : 0.1~5.0A(adjustable) *Max 25Watt
DC Input : 11.0-18.0V
AC Input voltage : AC100-240ACV 50~60Hz
(Auto adjusting)
Charging Capability : 0~9990mAh
Charging Modes : NiMh, NiCd, LiPo,LiFe,Lilo,Pb
Voltage Threshold/Delta Peak : Default・5~20mV/cell
Thermometer sensor : 20~80 Degrees celsius
Data store : 5 data of batteries
Keys : 4 button
LCD monitor : 16x2lines Blue LCD display
http://www.muchmoreracing.net/us/detail/mm-hbpk_b.htm
