RCmag :: Voir le sujet - Cale pour Mugen MBX6 et 6T King Headz
philippe27
MessagePosté le: 13.07.2010, 22:13:22    Sujet du message: Cale pour Mugen MBX6 et 6T King Headz Répondre en citant
Mugen MBX-6 Rear Toe-In Plate (2.5°,2.75°,3°) Delri
FEATURES: This Toe-In Plate is CNC machined from 7075 aircraft grade aluminum and Black Anodized. These are designed to increase rigidity and add strength. This toe-in plate will allow you to make 6 different toe/anti squat adjustments. By changing and flipping the pills you can adjust 6 different combinations from 2.5, 2.75 and 3 degree of toe-in with either zero degree of anti squat or one degree of anti squat.
INCLUDES:
(1) Rear Toe-In Plate (2.5°,2.75°,3°)
(1) Toe Plate O1 Off Center Hole Delrin Bushing
(1) Toe Plate O2 Off Center Hole Delrin Bushing
(2) Toe Plate Centered Hole Delrin Bushing
SPECS.
Material for Plate: 7075 Aircraft Billet Aluminum
Material for Bushings: Delrin
Weight: Toe-In Plate and (2) bushings 12.61 grams
Instruction Link: MBX6I-020
Replacement Bushings - Brass Link: MBX6-BS4
Replacement Bushings - Delrin Link: MBX6-BS4D
