AIRBAG is the revolutionary tyre insert developed and produced in Italy. Due to its unique and incredible features, AIRBAG is a must have for all serious racers.
Characteristics:
PERFECTLY BALANCED: just drop'em on and see the difference
ZERO CENTRIFUGATION: it means perfect contact of the tyre with the racing surface for improved traction and optimal steering response
TOTAL CONTROL: less side roll and less tyre wear
ULTRA RESISTANT: won't break as standard foams and don't collect dirt wihich can alter tyre responsiveness
PERFECT MATCH: they fit perfectly on the rim due to exclusive internal pattern
WATER RESISTANT: wash your tires without ani issue
DURABLE: can be used many times with multiple set of tires because they have no degrade
AIRBAG inserts are available in 3 different compounds:
RED: soft compound
YELLOW: medium compound
GREEN: hard compound
AIRBAG inserts are sold in set of 4 of same compound"
Posté le: 19.05.2010, 08:23:41 Sujet du message:
j'aimerai bien que notre expert français nous dise ce qu'il en pense....allez seb encore du taff pour toi _________________ amontintin lecerveaulent.........très lent, mais a quand même trouvé un sponsors.....mdr
