Cobra Sino Racing have announced the release of some new servos as well as a new charger. Their new Analogue servos come in 6kg and 9kg versions and are both metal geared with coreless motors and come with a blue anodized heat sink as part of the casing. They also have 2 new digital servos that have state of the art digital SMT technology, have coreless motors and also come with a blue anodized heat sink as part of the casing. These servos also use top of the line IC’s together with multiple layer circuits boards. There is also a new AC/DC Silent Charger, that is a state of the art microprocessor based charger/discharger system. The DiamondBack is a switch type unit and can fully charge 1 to 15 Ni-MH and Ni-Cd cells at a digitally preset amperage of up to a maximum 5.0A using peak detection and temperature limiting methods. The DiamondBack can also charge Lithium batteries up to 6 cells as well as lead acid cells.
Click more to see the other products…
These are two types of kg rating analogue servos. They come complete with heatsink,coreless motor and metals gears.
The Red heatsink is 13kg and the Blue heatsink is 9kg. Excellent for upgrading your RTR truggy or buggy with a high quality high speed and high torque metal geared servo.
Supply voltage 4.8v/6.0v
Speed 0.11sec/60 on load running
Torque 8kg/1cm 9kg/1cm
Wire length 180mm or 250mm
Size 41*42*21mm
Plug JR/FUTABA Spline futaba
Net Weight 58g Motor coreless
Supply voltage 4.8v / 6.0v
Speed 0.14sec/60 on load running
Torque 12kg/1cm 13kg/1cm
Size 41*38*20mm
Plug JR/FUTABA Spline Futaba
Net Weight 59g
Motor Coreless Motor
