RCmag :: Voir le sujet - Kit de conversion "dirt" XRAY pour XB2
MessagePosté le: 07.03.2018, 10:33:07    Sujet du message: Kit de conversion "dirt" XRAY pour XB2 Répondre en citant
#323325 Alu Rear Longer Lower Susp. Holder – Narrow – Rear (10mm)
#325002 Ball Adjust. Diff for 2.5mm Pin – Set – HUDY Spring Steel™
#325323 Rear Drive Shaft 71mm with 2.5mm Pin – HUDY Spring Steel™
#327310 Rear Suspension Pivot Pin 3×46 mm (2)
#363111-H Composite Suspension Arm Rear Lower Right – Hard
#363121-H Composite Suspension Arm Rear Lower Left – Hard
Source TeamXRAY
