RCmag :: Voir le sujet - GPTOYS RC Voiture ATV 4WD 4-Roue 40Km/h 2.4G émetteur
RCmag Index du Forum » Motos RC, dragsters, Karting ....
philippe27
MessagePosté le: 08.03.2017, 17:27:21    Sujet du message: GPTOYS RC Voiture ATV 4WD 4-Roue 40Km/h 2.4G émetteur Répondre en citant
Main Features:
* 4WD, running in all terrains;
* 30-40 minutes running time;
* Anti-crash bumper, add more fun;
* lightweight car---- full high-speed;
* Servos module----straight running without offtrack;
* Waterproof---- play in rainstorm and snow;
* when one wheel stuck, the other three wheels are still working;
* Nylon engineering material----the trunk body is more solid and flexible.
Product description:
Rirder5 S609 adopts the nylon engineering material, which has the excellent mechanical ability,durability, corrosion resistance and heat
resistance.It helps the truck body to become more solid and flexible. This two abilities also make the truck more suitable for all kinds of terrains.
Rirder5, RC ATV comes with 4WD system. Using one high-speed motor to power four tires to realize the ambition of high-speed driving.
More stable and more rapid.
The AVT is light enough that it's almost floating on top of the grass.180 high-speed brushed motor,30-40 minutes running time,
more anti-crash, low friction & high grip, experience incredible fun.
Running in pavement, gravel, dirt, beach, ditch, snow.
Specification:
Product Weight: 0.313KG
Package Weight: 1.000KG
Color: White and Blue
product Size (L x W x H): 18.5*14*9cm
Package Size (L x W x H): 21.5*17*21cm
Radio System: 2.4GHz
Front/Rear Tires (glued): Soft-Compound Slicks
Drive System: Shaft-Driven 4WD
Battery Type: Li-ion
Battery Voltage: 3.7v
Battery Capacity: 800mAh
Charging Time: about 120minutes
Playing Time : about 30min
The topspeed : about 40Km/h
Remote Controller
Operating Frequency: 2.4GHz
Max Transmission Distance: 100m
Battery: 3xAAA Batteries
Packages Included:
1 * GPTOYS Rirder5 S609 OFF-ROAD ATV
1 * 2.4G transmitter
1 * USB charging wire
1 * Battery charging box
2 * 3.7V 800mAh Li-po batteries
4 * Spare tires
1 * screwdriver
1 * Hexagon wrench
4 * Pins
1 * Instruction manual
philippe27
MessagePosté le: 08.03.2017, 17:28:16    Sujet du message: Répondre en citant
Poster un nouveau sujet   Répondre au sujet    Haut de page » Accueil » RCmag Index du Forum » Motos RC, dragsters, Karting .... Toutes les heures sont au format GMT + 1 Heure
