RCmag :: Voir le sujet - Volkswagen Golf Mk.1 Racing Group 2 (M-05 Chassis)
MessagePosté le: 27.01.2016, 11:13:58    Sujet du message: Volkswagen Golf Mk.1 Racing Group 2 (M-05 Chassis) Répondre en citant
Pour ceux qui aiment la marque qui triche Laughing Tamiya relance une série limitée de sa Volkswagen Golf Mk.1 Racing Group 2 (M-05 Chassis)
Ref No: 47308
The Comeback of a Classic!
This R/C model assembly kit depicts the striking Kamei-sponsored Group 2 VW Golf which made a splash in 1970s touring car racing. The polycarbonate body accurately captures the form of the racing Golf, with wide front fenders and a sporty front spoiler. Stickers are included to recreate sponsor logos, numbers, etc.
M-05: Low Center of Gravity, High Performance!
The front wheel drive M-05 chassis features a lightweight, narrow, durable, and easy-assembly semi-monocoque resin frame. Gearbox, motor, battery pack, receiver, servo and ESC are positioned for optimum weight distribution and a low center of gravity. Ground-hugging 4-wheel independent double wishbone suspension and the 3-piece steering linkage provide stable high-speed cornering. Racing slick tires feature tire inserts.
Specifications
●Length: 329mm, Width: 175mm, Height: 120mm ●Wheelbase: 210mm ●Tread (Front & Rear): 138mm ●Tire Width/Diameter (Front & Rear): 25/55mm ●Monocoque Frame ●3-Bevel Differential Gear ●Front-Wheel 2WD ●3-Piece Steering Tie-Rod ●4-Wheel Double Wishbone Suspension ●Front & Rear Friction Dampers ●Gear Ratio = 5.8:1 ●Type 540 Motor ●Requires an Electronic Speed Controller (sold separately)
スペース
Separately Required Items
●2-Channel R/C System w/ESC ●R6/AA/UM3 batteries for transmitter ●Battery Pack & Charger
Laughing
MessagePosté le: 27.01.2016, 11:22:16    Sujet du message: Répondre en citant
J'imagine bien des courses de golf
Lalsacien
MessagePosté le: 04.02.2016, 15:18:51    Sujet du message: Répondre en citant
Pour ceux qui voudrait faire rouler leur Golf ou tout autre M-châssis de la marque aux étoiles, il existe un club, le MOCDL OK!
Anciennement localisé à Dammarie les Lys, le club ouvre désormais ses portes chaque mardi soir à la base de loisir de Seine-Ecole à Saint-Fargeau Ponthierry (77).
Vous pourrez y faire évoluer tous châssis piste 1/10ème électrique, mais l'écrasante majorité roule avec des châssis typés loisir comme les M-châssis, ou encore des F1.
Châssis vintage, carrosseries scale réalistes, tractions, propulsions Very Happy on se fait plaisir sans course à l'armement.
Une Cup est organisée régulièrement, M-châssis, moteur Sport Tuned à charbons, pneus tamiya, de belles bagarres avec des performances identiques avec l'esprit loisir.
Une vidéo pour se faire une idée Very Happy
https://www.youtube.com/watch?v=jXU150sA1E0
Si un admin passe dans le coin histoire de rendre le lien youtube plus sexy... Embarassed
J.O.
YaYa
MessagePosté le: 04.02.2016, 17:26:28    Sujet du message: Répondre en citant
Aussitôt dis, aussitôt fait OK!
Lalsacien
MessagePosté le: 04.02.2016, 19:18:09    Sujet du message: Répondre en citant
Merci OK!
un peu plus de monde sur la piste en milieu de séquence Shocked
J.O.
