Normal, Horizon Hobby distribue Yunecc ( drone, skate électrique,...), qui leur fournit même la radio du Chroma, et tous les écrans de leurs radio sont sous Androïd _________________ Gentil papy boomer un peu anar complétement déjanté
si en plus c'est façon android c'est un énorme plus _________________ rcmag.com pour le forum, les photos et vidéos
Intuitive, full-color, Android-powered touch screen
WiFi connectivity for firmware updates and apps
Built-In Telemetry
Bluetooth model transfer for use with other DX6Rs
Wireless link for compatible FPV headsets
5.5-millisecond frame rate with compatible receivers
Superb ergonomics you can customize
Voice alerts over speaker or through headphones
250-model memory
AVC® programming for compatible receivers
Includes SR6000T and SR2000 receivers
Long-lasting Li-Ion battery with charging base
EN328 compatible
Overview
The DX6R smart radio will transform your driving experience. Touch-screen simplicity, WiFi connectivity, unbeatable DSMR® range and security, 5.5ms frame rates, telemetry, Bluetooth model transfer – you get it all and more..
Android-Powered Touch Screen or Scroller
You can literally 'tap' into the DX6R's programming features using an Android-powered, touch screen. Long-time Spektrum users who prefer the more tactile scrolling selector can use it. Whichever input you use, the big color display makes navigating menus and adjusting settings as easy as it gets.
WiFi Connection for Updates and Apps
When connected to WiFi, the DX6R gets even smarter. You can instantly make firmware and RaceWare™ updates, download model setups from other users and add approved third-party apps. The DX6R will even be able to alert you when new updates or setups become available.
Bluetooth Model Transfer
If you’re out driving with another DX6R owner, you can quickly and easily swap model setups via Bluetooth. No WiFi or SD card transfer necessary. Just link up and swap.
Built-In Telemetry
The built-in telemetry feature can give you real-time information on things like your vehicle's battery voltage, signal quality, motor temperature and more.* Using the voice alert system, you can program the DX6R to tell you when specific telemetry values reach or exceed limits you define. You can also have it call out a sequence of telemetry values on demand with the flip of a switch.
*Vehicle must be equipped with a telemetry-enabled receiver like the included SR6000T.
Frequency-Agile DSMR® Technology
The DX6R is built around frequency-agile, DSMR 2.4GHz technology. This exclusive Spektrum™ technology can be used in any type of surface application, including boats. Its range and response, particularly in noisy 2.4GHz environments, are superb. It's also backwards compatible with DSM2® and marine-specific Spektrum receivers. This means most longtime Spektrum users can continue to use the receivers they have. They’ll only need to upgrade if they want the frequency-agility of a DSMR receiver for busy 2.4GHz environments.
Superb Ergonomics
Optimized weight distribution and an abundance of adjustable features make it easy to customize the DX6R’s ergonomics to your driving style. You will enjoy a sense of balance and comfort that perfectly complements the precision of DSMR technology, especially during long racing heats.
Ergonomic features include:
Multiple wheel angle settings
Adjustable trigger and steering tension
Adjustable trigger position (fore-to-aft and side-to-side)
Left- or right-hand steering
Multiple drop-down options
Three grip sizes
Smooth, dual-ball bearing precision
Wireless Link for Spektrum FPV Headsets
This exclusive Spektrum technology makes it possible to link with specially-equipped Spektrum FPV headsets so you can wirelessly control head tracking or remotely change video frequencies.
5.5-Millisecond Frame Rate
When matched with a receiver capable of 5.5ms frame rates, the DX6R delivers lightning-fast response that gives new meaning to the word ‘connected’.
250-Model Memory
The enormous capacity of the DX6R’s on-board memory means you will rarely, if ever, need to juggle models between transmitter memory and your SD card.
Includes SR6000T Telemetry and SR2000 Race Receivers
You can take advantage of all six channels and telemetry functions with the included SR6000T. A tiny SR2000 Race Receiver capable of a 5.5-millisecond frame rate is also included.
Programmable Voice Alerts
Keep tabs on important information without ever taking your eyes off what you’re driving. With the programmable voice alert system, you can have the DX6R call out lap times or report telemetry information. If an alarm goes off, you won’t have to look at the display to see what’s happening. The DX6R will tell you.
In addition to a built-in speaker, the DX6R has a headphone jack that allows you to monitor voice alerts using earbuds so you don’t bother other drivers.
Programming Features
The DX6R comes with an impressive list of programming features, some of which include:
Up to 3 drive modes per model
Programmable mixes
7-Point throttle and steering curves
Voice alert programming
Dual rates and expo
And more!
Charging Base
You don’t have to remove the battery of plug in the transmitter when it comes time to recharge. The DX6R includes a handy charging base that doubles as a transmitter holder. Its compact footprint won’t clutter up your pit station or workbench either. _________________ rcmag.com pour le forum, les photos et vidéos
Posté le: 27.01.2016, 17:39:52 Sujet du message:
SPM6400EU Spektrum DX6R = 574.99 €
La DX6R va transformer votre manière de piloter. La simplicité de son écran, sa connectivité Wi-Fi, Fréquence et sécurité DSMR, son taux de réponse 5.5ms, sa télémétrie, son transfert de modèle en Bluetooth – vous pourrez profiter de toutes ces caractéristiques et plus encore. Que vous soyez fan de tout-terrain ou de circuit, les caractéristiques et capacités de la DX6R vont révolutionner votre conduite.
Ecran tactile Android ou volant
Vous pouvez accéder aux fonctions programmables en utilisant l’écran tactile Android. Pour les habitués plus traditionnels des radios Spektrum vous pourrez utiliser le volant pour faire votre sélection. Peu importe votre choix, le grand écran LCD vous permettra de naviguer dans les menus et réglages en simplicité.
Connection Wi-Fi pour les mises à jour et applications
Lorsqu’elle est connectée au Wi-Fi, la DX6R vous propose encore plus de fonctions. Vous pouvez télécharger les mises à jour instantanément pour les logiciels et RaceWare, télécharger les réglages de modèles d’autres utilisateurs et des applications. La DX6R vous préviendra même lorsque de nouvelles mises à jour ou applications seront disponibles.
Transfert de modèle en Bluetooth
Si vous êtes avec un autre pilote possédant une DX6R, vous pourrez rapidement échanger les réglages modèles via Bluetooth en toute simplicité. Pas besoin de Wi-Fi ou carte SD pour faire le transfert. Il suffit de se connecter et partager.
Télémétrie intégrée
La télémétrie intégrée vous donne des informations en temps réel comme le niveau de la batterie de votre véhicule, la qualité du signal, la température du moteur et plus encore.* Avec le système d’alerte vocale, vous pouvez régler votre DX6R pour qu’elle vous prévienne quand vous approchez ou dépassez les limites que vous avez réglées. Vous pouvez également assigner un interrupteur pour basculer dans une séquence de valeurs télémétrie que vous aurez définie.
* Le véhicule doit être équipé d’un récepteur compatible avec la télémétrie comme le SR6000T inclus.
Technologie à saut de fréquence DSMR
La DX6R est fabriquée autour de la technologie à saut de fréquence DSMR 2.4GHz. Cette technologie Spektrum peut être utilisée sur tous les modèles surface, même sur les bateaux. Elle vous délivre une portée et une réponse supérieure dans tous les types d’environnements et surtout quand il y a beaucoup de systèmes en 2.4GHz utilisés simultanément. Elle est compatible avec les récepteurs Spektrum DSM2 et marine. Ainsi, les utilisateurs Spektrum pourront utiliser les récepteurs qu’ils ont déjà.
Une ergonomie travaillée
Une distribution du poids optimisée et de nombreuses fonctions réglables vous permettent de personnaliser votre DX6R par rapport à votre style. Le confort et l’équilibre s’ajoute à la précision de la technologie DSMR pour vous aider, en particulier lors de longues courses.
Multiples réglages de l’angle du volant
Tension de la gâchette et de la direction réglables
Position de la gâchette réglable
Compatible droitier ou gaucher
3 grips de tailles différentes
Liaison sans fil avec lunettes FPV Spektrum
Cette technologie Spektrum vous procure une liaison sans fil avec les lunettes Spektrum FPV pour pouvoir contrôler le Head tracking ou changer librement de fréquence.
Taux de réponse de 5.5ms
Lorsqu’elle est combinée avec un récepteur compatible 5.5ms, la DX6R délivre un taux de réponse rapide qui donne un nouveau sens au mot ‘connecté’.
Mémoire 250 modèles
L’incroyable mémoire interne de la DX6R vous permettra de stocker un grand nombre de modèles sans à avoir à jongler entre votre émetteur et une carte SD.
Récepteurs Télémétrie SR6000T et SR2000
Vous pourrez profiter des 6 voies et des fonctions télémétrie avec le SR6000T inclus. Un récepteur SR2000 compatible 5.5ms est également inclus.
Alertes vocales programmables
La DX6R vous permet de garder un œil sur les fonctions importantes sans quitter votre modèle des yeux. Vous pouvez programmer des alertes vocales pour vous indiquer votre temps au tour ou donner des informations télémétrie sur demande. Si une alarme retentit, vous n’aurez pas besoin de regarder l’écran pour savoir ce qui se passe. La DX6R vous le dira.
En plus de son haut-parleur, la DX6R possède une prise jack pour contrôler les alertes vocales à l’aide d’écouteurs pour ne pas déranger les autres.
Fonctions programmables
La DX6R présente une liste impressionnante de fonctions programmables comme:
Jusqu’à 3 modes par modèle
Programmation AVC pour récepteurs compatibles
Mixages programmables
Courbes de gaz et direction à 7 points
Alertes vocales
Double-débattements et expo
Et plus encore!
Station de charge
Pas besoin de retirer la batterie de l’’émetteur pour la recharger. La DX6R a une station de charge qui se transforme également en support pour l’émetteur. Son format compact vous fera gagner de l’espace.
Caractéristiques générales
Ecran tactile Android intuitif couleur
Connexion Wi-Fi pour mises à jour logiciel et applications
Télémétrie intégrée
Transfert de modèle via Bluetooth avec les autres DX6R
Liaison sans fil avec lunettes FPV compatibles
Taux de réponse de 5.5ms avec les récepteurs compatibles
Ergonomie travaillée personnalisable
Alertes vocales via haut-parleurs ou écouteurs
Mémoire 250 modèles
Programmation AVC pour les récepteurs compatibles
Récepteurs SR6000T et SR2000 inclus
Batterie Li-Ion avec station de charge
Compatible EN328 _________________ Vignier cyrille
Le LapMonitor est compatible avec la DX6R. Ce qui permet d'avoir directement vos temps et les annonces vocales sur votre telecommande !
Compatible uniquement pour les telecomandes DX6R fabriquées à partir de mars 2018 (Pour l'affichage de l'application sur la telecommande, sinon le LapMonitor est comptatible avec toutes les telecommandes si vous utiliser votre telephone pour vous connecter au LapMonitor)
