RCmag :: Voir le sujet - *Le buggy Hobao hyper VS *
*Le buggy Hobao hyper VS * Aller à la page 1, 2, 3  Suivante
lulu97
MessagePosté le: 06.07.2015, 17:17:22    Sujet du message: *Le buggy Hobao hyper VS * Répondre en citant
Nouveauté Hobao. Source Fb: Hobao Racing.
MessagePosté le: 06.07.2015, 18:38:03    Sujet du message: Répondre en citant
curieux de voir cela, si c'est du réchauffé ou pas OK!
speedy2
MessagePosté le: 06.07.2015, 19:09:58    Sujet du message: Répondre en citant
On dirait plutôt du RTR ? voir un SS nitro
Phred
MessagePosté le: 07.07.2015, 00:41:16    Sujet du message: Répondre en citant
typé loisir ou compétition, un Hobao reste un Hobao : fiable et performant !
speedy2
MessagePosté le: 20.08.2015, 13:45:09    Sujet du message: Répondre en citant
HoBao's upcoming new 1/8 buggy, Hyper VS, is at the final production stage and will be available at various distributors very soon.
The new Hyper VS is very easy to drive, very stable with great cornering control. The buggy is manufactured with high quality material with excellent fit and finish.
Further more, there will be lots of option parts for you to soup-up your Hyper VS for the real race!
Both nitro and electric versions are available.
Features: Nitro:
-2.4GHz radio system
-Hyper 21 / Mac 28 / Hyper 30 engine options (depending on distributors)
-Heavy duty throttle and steering servos
-New painted body design
-New chassis design
-New rigid front (4mm) and rear (3mm) shock towers
-New strengthened front and rear suspension arms
-New extra battery compartment for Lipo battery
-Enclosed radio box
-125cc gas tank
-17mm big bore threaded shocks (4mm shaft)
-Rear mud guards
-Full ball bearings
-New C-Hub design
-Front universals
-Hard anodized aluminum parts throughout the car
-Polished tuned pipe
-Dual stage air filter assembly
-Front and rear sway bars
Electric:
-Hobbywing 100amp high performance water proof brushless system
-Large battery tray with three velcro straps
-Enclosed radio box
speedy2
MessagePosté le: 24.08.2015, 23:01:31    Sujet du message: Répondre en citant
speedy2
MessagePosté le: 24.08.2015, 23:02:06    Sujet du message: Répondre en citant
speedy2
MessagePosté le: 24.08.2015, 23:02:46    Sujet du message: Répondre en citant
speedy2
MessagePosté le: 24.08.2015, 23:04:16    Sujet du message: Répondre en citant
speedy2
MessagePosté le: 24.08.2015, 23:04:46    Sujet du message: Répondre en citant
Modérateur le 25.08.2015, 11:13:16; édité 1 fois
speedy2
MessagePosté le: 25.08.2015, 11:08:21    Sujet du message: Répondre en citant
Cela fait plutôt du Hyper 8.9 rtr
En general, ce que j'aime moins, c'est la finition voir le style-même pas trop raffiné, voir trop Chinois, de Hobao
.. comme les systèmes de cales alu où les axes passent dedans presque sans inserts, avec le jeu qui vient de suite.. bof je fais tilt..
Cela me fais penser un peu aux HB lightnings dans le temps
aussi les supports qui plient d'habitude.. et ici la batterie sans boite de prévue encore..
Mais c'est bien que une marque sort un modèle pas cher..
Modérateur le 10.07.2019, 22:44:23; édité 17 fois
philippe27
MessagePosté le: 03.10.2015, 22:26:03    Sujet du message: HoBao Hyper VS/VSe Released Répondre en citant
speedy2
MessagePosté le: 25.10.2015, 16:45:25    Sujet du message: Répondre en citant
Pilote Hyper espagnol avec le VS..
Modérateur le 21.02.2016, 19:18:16; édité 2 fois
MessagePosté le: 25.10.2015, 17:39:23    Sujet du message: Répondre en citant
il a finalement pas beaucoup changé comparé au SS
speedy2
MessagePosté le: 08.02.2016, 16:20:15    Sujet du message: Répondre en citant
Le Hyper VS de Andres Marcelino ES.
Modérateur le 08.02.2016, 23:11:39; édité 1 fois
speedy2
MessagePosté le: 08.02.2016, 16:26:32    Sujet du message: Répondre en citant
Les options.. mais alors cela devient cher..
https://www.rcmag.com/modules.php?name=Forums&file=viewtopic&t=62600
Modérateur le 28.01.2018, 11:33:03; édité 2 fois
speedy2
MessagePosté le: 08.02.2016, 16:45:19    Sujet du message: Répondre en citant
DaTaz
MessagePosté le: 08.02.2016, 20:29:25    Sujet du message: Répondre en citant
Y a un bon paquet de pièces, je les avais déja vues sur mes Hyper 8.5...
Pins25
MessagePosté le: 09.02.2016, 12:09:20    Sujet du message: Répondre en citant
Visiblement la plupart des pilotes passent sur des amortisseurs Mugen. Une fragilité sur ceux d'origine ?
MessagePosté le: 09.02.2016, 18:43:03    Sujet du message: Répondre en citant
vu le prix des amortisseurs mugen on dépasse le budget raisonnable ....
YaYa
MessagePosté le: 09.02.2016, 18:58:40    Sujet du message: Répondre en citant
On n'en voit pas beaucoup en France, c'est mal distribué ?
max0312
MessagePosté le: 12.02.2016, 13:53:22    Sujet du message: Répondre en citant
bizarre que l'ont en voient pas plus car le ss et quand meme performant et tres robuste vu les tarifs
speedy2
MessagePosté le: 21.02.2016, 15:57:47    Sujet du message: Répondre en citant
Andres Marcelino me dit que la voiture roule très bien, il fait souvent top 3 avec dans les courses en Espagne ..
Full options, ils utilisent les shocks Mugen, parce qu'ils les connaissent bien... "ceux de Hyper pas essayer même.."
Les shocks Hyper sont performants d'habitude, non ?
Modérateur le 02.03.2018, 11:12:52; édité 12 fois
speedy2
MessagePosté le: 21.02.2016, 15:58:21    Sujet du message: Répondre en citant
speedy2
MessagePosté le: 21.02.2016, 19:19:39    Sujet du message: Répondre en citant
Modérateur le 29.01.2018, 13:47:42; édité 2 fois
speedy2
MessagePosté le: 29.02.2016, 11:19:30    Sujet du message: Répondre en citant
speedy2
MessagePosté le: 08.04.2016, 10:58:55    Sujet du message: Répondre en citant
pirapoulp
MessagePosté le: 12.04.2016, 10:41:32    Sujet du message: Répondre en citant
Question sans réponses, qui s'occupe et vend les pièces hobao en France?
speedy2
MessagePosté le: 12.04.2016, 11:58:08    Sujet du message: Répondre en citant
Wartelle a du Hyper..
pirapoulp
MessagePosté le: 12.04.2016, 17:15:17    Sujet du message: Répondre en citant
Oui effectivement, mais je n'ai pas vu la vente de pièces détachées sur le site.
C'est ce qui me retiens d'investir.
Page 1 sur 3
