RCmag :: Voir le sujet - MT-4S 40 Years Sanwa Edition incl. 2 Receivers, Aluminum Whe
philippe27
MessagePosté le: 03.03.2015, 23:16:56    Sujet du message: MT-4S 40 Years Sanwa Edition incl. 2 Receivers, Aluminum Whe Répondre en citant
MT-4S 40 Years Sanwa Edition incl. 2 Receivers, Aluminum Wheel
40 years Sanwa – the limited special edition of the MT-4S with new features.
Art. no.: 101A31575A
This is Sanwa MT-4S 40th Anniversary Edition Radio. In honour of the 40th anniversary of the company, Sanwa releases a special edition of the MT-4S! Therefore, the engineers upgraded the “M12 in small size” with new technical and visual features. The MT-4S 40 Years comes in a special black piano lacquer design and with grip plates designed accordingly, while the steering wheel is made from aluminium.
Depending on the receiver you choose, telemetry data like motor / engine temperature, rpm, drive battery or receiver battery voltage can be displayed and stored to the computer also with the MT-4S 40 Years.
The telemetry data is displayed on a large full-dot LC-display. Due to the integrated background illumination, improved legibility of information and set-up is guaranteed. The Sanwa Vortex Zero Brushless speed control can be programmed directly from the transmitter as the MT-4S features the SSL function of the M12.
SSL Supported (Sanwa Synchronized Link)
4-Channel 2.4GHz FH4T Digital High-Response Telemetry System with Advanced Programming
Backlit LCD Screen Allows You to Easily View Programming Options and Telemetry Data in All Types of Conditions
High-Power FH4T Technology Provides the Best Reception and Connectivity, Giving Racers Added Assurance
4 Cell Dry Battery Holder for Lighter Weight - Also Accepts Optional NiCd/NiMH or 2S LiPo/LiFe Battery Packs
18-Model Memory
Telemetry Logging
Channel-Set Menu
Servo Reversing
Steering, Throttle and Brake Dual Rate
End-Point Adjustment
Exponential and ARC Adjustment
Servo-Speed Adjustment
Anti-Lock Braking
Throttle Offset
Lap and Interval Timers
Total, Best and Individual Lap Display
Four-Wheel Steering Mixing
Dual Throttle Mixing w/Dig & Burn
Normal, SSR and SHR Servo Modes
Center or Parallel Trim Types
MT-4S specification:
Output Power: 100mW
Nominal Input Voltage: 4.8v to 7.4v
Operating Voltage Range: 4.0v to 9.6v
Weight: 388g
Frequency: 2.4GHz FHSS
Modulation Type: FH2, FH3, FH3F, FH4T, FH4FT
RX-472 specification:
Nominal Input Voltage: 3.7v to 7.4v
Weight: 0.23oz (6.6gr)
Dimensions: 30.0 x 23.3 x 14.0mm
Frequency: 2.4GHz FH3/FH4T Selectable Via Transmitter
Fail Safe Support: Yes (All Channels)
Battery Voltage Fail-Safe Limit: 3.5-5.0v (FH3) / 3.5-7.4v (FH4T)
RX-471 (Dual ID) specification:
Frequency: FHS 2.4GHz
Power supply: 4.8v - 7.4v
Dimensions: 30mm x 23.3mm x14mm
Weight: 6.6g
Sanwa MT-4S 2.4GHz 40th Anniversary Transmitter x1
RX-471 (dual id) receiver x1
RX-472 receiver x1
SRM 102 servo x2
40th Anniversary Carrying Bag x1
Switch x1
Battery holder x1
Extra Handle Grip x1
Manual
https://www.lrp.cc/en/products/coming-soon/produkt/rx-461-empfaenger-fuer-mt-4-fhss-4t/details/
http://www.lrp.cc/en/products/vtec-batteries/transmitter-batteries/produkt/lrp-vtec-lipo-3000-tx-pack-sanwa-m12mt-4exzes-xsd-10g-tx-only-74v/details/
https://www.lrp.cc/fileadmin/lrp_pdfs/10/101A31575A-1.pdf
http://www.airtronics.net/index.php/radios-receivers/2-4-ghz-surface-radios-1/airtronics-mt-4s-40th-anniv-w-case-472-471d-id-rx.htm
http://www.sanwa-denshi.com/rc/car/propo/mt-4s.html
Etan
MessagePosté le: 04.03.2015, 06:37:04    Sujet du message: Répondre en citant
Magnifique OK!
RC10 WorldCar
www.rc-cmat.fr
madau
MessagePosté le: 04.03.2015, 07:37:21    Sujet du message: Répondre en citant
dispo quand ???? si un revendeur pense l'avoir peut t'il me contacter en mp merci
miniwheels
MessagePosté le: 04.03.2015, 17:17:51    Sujet du message: Répondre en citant
Elle est déjà dispo!
