RCmag :: Voir le sujet - Boite de visserie TLR pour gamme 22, avec la visserie !
MessagePosté le: 26.11.2014, 09:52:02    Sujet du message: Boite de visserie TLR pour gamme 22, avec la visserie ! Répondre en citant
#TLR334023
Le contenu:
Qty. Description
Vis
2 M3 x 5mm, Button Head
2 M3 x 6mm, Button Head
6 M3 x 8mm, Button Head
6 M3 x 10mm, Button Head
4 M3 x 12mm, Button Head
2 M3 x 14mm, Button Head
2 M3 x 16mm, Button Head
2 M3 x 18mm, Button Head
2 M3 x 20mm, Button Head
2 M3 x 35mm, Button Head
2 M3 x 40mm, Button Head
2 M3 x 44mm, Button Head
1 M3 x 54mm, Button Head
2 M3 x 5mm, Cap Head
2 M3 x 6mm, Cap Head
2 M3 x 16mm, Cap Head
2 M3 x 20mm, Cap Head
2 M3 x 5mm, Flat Head
4 M3 x 8mm, Flat Head
6 M3 x 10mm, Flat Head
6 M3 x 12mm, Flat Head
4 M3 x 16mm, Flat Head
2 M3 x 18mm, Flat Head
2 M3 x 20mm, Flat Head
2 M3 x 25mm, Flat Head
2 M2.5 x 4mm, Button Head
2 M2.5 x 8mm, Button Head
2 M2.5 x 12mm, Button Head
2 M2.5 x 6mm, Flat Head
2 M2 x 6mm, Flat Head
2 M2 x 8mm, Flat Head
2 M2 x 5mm, Cap Head
2 M2 x 12mm, Button Head
2 M2.5 x 0.45mm x 5mm Set Screw
2 M2.5 x 0.45mm x 20mm Set Screw
2 M3 x 0.5mm x 2.5mm Set Screw
2 M3 x 0.5mm x 5mm Set Screw
2 M3 x 0.5mm x 12mm Set Screw
2 M3 x 0.5mm x 16mm Set Screw
Ecrou
2 M4 x 7mm Black Alum Locknut, Serrated
2 M4 x 7mm Low Profile Steel Nut, Serrated
8 M3 x 5.5mm Locknut
2 M2.5 x 5mm Locknut
Rondelle
2 Copper Washer, 22 Bleeder Caps
2 .5mm Spindle Spacer, 22
2 1mm Spindle Spacer, 22
2 2mm Spindle Spacer, 22
2 .5mm Shock Shaft Limiter
2 1mm Shock Shaft Limiter
2 2mm Shock Shaft Limiter
4 3mm x .5mm Black Washer
2 5mm x 7mm x 0.2mm Shim
Special
2 Front Axle Lug, 22 Buggy
2 King Pin Screw, 22-4
4 Black Body Clip
2 Solid Axle Pin
2 Pin, 2mm X 10mm
2 Pin, 2mm x 8mm
2 Crush Pin, 1/16" x 7/16"
2 C-Clip, 3/16"
4 E-Clip, 2.5mm
www.teamlosiracing.com
hobaonene
MessagePosté le: 26.11.2014, 14:18:26    Sujet du message: Répondre en citant
on ne peut pas accéder a t'on site dommage
MessagePosté le: 26.11.2014, 14:40:13    Sujet du message: Répondre en citant
Smile
http://www.tlracing.com/Products/Default.aspx?ProdID=TLR336002
hobaonene
MessagePosté le: 26.11.2014, 14:49:54    Sujet du message: Répondre en citant
Papymini a écrit:
Smile
Merçi
