RCmag :: Voir le sujet - Nouvelle radio Kyosho Syncro Touch KT-432P
MessagePosté le: 04.10.2014, 08:25:03    Sujet du message: Nouvelle radio Kyosho Syncro Touch KT-432P Répondre en citant
Vous l'aurez reconnu, c'est idem avec la radio Absima il me semble OK!
MessagePosté le: 04.10.2014, 08:30:57    Sujet du message: Répondre en citant
Elle est présentée avec une Mini Z donc on peut espérer sa compatibilité ce qui serait une "révolution" pour les gaucher et niveau technologique dans cette catégorie.
Pilydount
MessagePosté le: 04.10.2014, 10:35:32    Sujet du message: Répondre en citant
Selon Kyoshosan, cette radio est dédiée à la miniZ sports.
http://kyoshosan.blogspot.fr/2014/09/extra-new-tx-for-mini-z-sports-syncro.html
Cordialement
philippe27
MessagePosté le: 12.03.2016, 22:22:15    Sujet du message: Répondre en citant
https://www.kyosho.com/eng/products/rc/detail.html?product_id=110288
This is the Kyosho Syncro Touch KT-432PT 2.4GHz 4 Channel Transmitter. The Syncro Touch KT-432PT FHS/FHSS 2.4GHz transmitter is a perfect upgrade for your KT-19 transmitter equipped model. In fact, its compatible with any model equipped with a KR-331/431T receiver installed, as well as the full range of Mini-Z series vehicles! In addition to increased control and improved response, but the standout feature of the KT-432PT is the color touch panel that creates a control feel similar to a smartphone!
The Syncro Touch KT-432PT not only creates a new evolution in performance, but also takes the visual and user experience to the next level as well. The Syncro Touch menu is rich with setting options from end-point, exponential, mixing and model memory (20 models), but also displays these in a user-friendly graphical and illustrated format like a smartphone. Plus when you switch the power ON/OFF, the internal speaker plays the start up sound of a racing car! Kyosho’s philosophy of “serious about having fun” is embodied in this next generation transmitter by enhancing the enjoyment of operating a transmitter and driving R/C cars at the same time.
Features:
Steering wheel position can be adjusted by extension. 5 trim switches are positioned around the steering wheel and 2 push switches are located near the grip for easy reach and control.
While still a mid-range transmitter, the symmetrical design allows easy conversion for left-handed users by changing the installed extension.
Easy visuals from the large 3.35-inch full color touch panel display brings smartphone-like control to R/C car transmitters. Popular language choice settings are available such as English and Japanese.
Setting screen features 23 menu icons, more than enough for a mid-range transmitter. Illustrations are easy to understand and provide direct access and control of menu selections.
Use of graphical and illustrated displays presents information on screen in the easiest to understand format. Control with the flick of a finger, just like a smartphone screen (photo shows steering exponential setting screen).
Next generation transmitter with large full color touch panel display is ideal as upgrade from KT-19.
Two built-in protocols: FHS Mini-Z and FHSS.
Compatible with other R/C models installed with KR-331/431T receiver, in addition to Mini-Z series.
Data from optional temperature/voltage sensor can be displayed on screen. (only when using KR-431T receiver)
Equipped micro USB port allows firmware updates to be installed.
Control feel of throttle trigger and steering wheel can be adjusted by changing position and spring tension.
Lightweight - 398g is easy to hold for long drive times.
Specifications:
Channels: 4-channel
Weight: 398g
Power supply voltage: 4 x AA alkaline batteries
Compatible Models: Cars & Boats
RF Range: 2.405-2.475GHz
2.4GHz System: FHS (MINI-Z) / FHSS 1Way (KR-331) / FHSS 2Way (KR-431T)
Low Voltage Warning: below 3.7V
Steering Range: 66° (left/right 45°)
Throttle Range: 45° (forward/reverse 30°)
Authentication: CE0678.FCC
Includes:
KT-432PT transmitter unit
Grip rubber (L size)
Micro USB cable
This product was added to our catalog on September 28, 2015.
KYOSHO - EMETTEUR SYNCRO TOUCH KT-432PT 82136
La radio Kyosho Syncro KT-432PT est une radiocommande tactile avec écran couleur, elle offre la même sensation qu'avec un smartphoneet permet de régler toutes les fonctions.
L'émetteur 2.4GHz Syncro tactile FHS / FHSS est une mise à niveau idéal par rapport à la KT-19 qui est inclus avec le MR-03S / MA-020S / Overland Sports, Mini-Z Sport de série, et les modèles Mini-Z Racer Moto. En plus d'une meilleure réactivité et la précision de contrôle, l'autre caractéristique remarquable de la Syncro tactile KT-432PT est l'écran tactile couleur qui crée un contrôle comme avec un smartphone. Comme d'autres émetteurs de milieu de gamme, le menu Syncro Touch est riche avec des options de réglage de fin de course, exponentielle, le mélange et le modèle mémoire (20 modèles), mais affiche également ceux-ci dans un format graphique. Couper l'alimentation ON / OFF et entendre le son de démarrage d'une voiture de course du haut-parleur interne. Le Syncro tactile KT-432PT non seulement réalise une évolution dans la performance, mais prend également l'expérience visuelle et l'utilisateur à un tout nouveau niveau.
A noter que cette radio fonctionne avec les Mini-Z Sports (FHS) et n'est pas compatible avec les Mini-Z (ASF).
Equipement nécessaire (non inclus) :
• 4 Piles LR06 pour la radio
[url]
[/url]
https://www.youtube.com/watch?v=Y_sTYuy6SCE
