RCmag :: Voir le sujet - Thunder Tiger EB4 G3 1/8 Brushless Buggy
philippe27
MessagePosté le: 11.09.2014, 08:47:51    Sujet du message: Thunder Tiger EB4 G3 1/8 Brushless Buggy Répondre en citant
EB-4 G3 1:8 Brushless Buggy (2014 New Style)
[url][/url]
Though racer is ready to conquer straight out of the box, more options of aggressive styles are needed. Have fun and enjoy the exciting world of R/C. Thunder Tiger is proud to release the EB-4 G3 brushless powered racing buggy with New shell design and improvement of rear wing!
The EB-4 S3, winner of the US-American ROAR Championship has proven it as the best R/C off-road machine in the world. Now The new revision of body styling makes it more attractive! And the aerodynamically rear wing improves low center of gravity, aided by a steeply inclined rear wing, aerodynamic forces exert whole car's weight, enhancing EB-4 G3 grip to the road. The New styling of EB-4 G3 remains some outstanding features, but more attractive and stability.
1/8 Scale Affordable Brushless System Now Is Available!
Thunder Tiger Corp. is pleased to announce the brand new ACE RC brushless speed control and motor for 1/8 scale R/C vehicles. ESC is now available in 80A and 150A, in which the former is perfectly used for buggy and truggy while the latter is mainly used for power-on-demand monster trucks as well as 1/5 scale. The ACE RC IBL4020 2000Kv super brushless system not only provides amazing torque and speed potential for your 1/8 scale vehicle, but supplies a longer operation time due to less friction in the brushless motor compared with other sensored systems. Also ACE RC brushless speed control is compatible with all sensorless brushless motors and most of sensored brushless motors such as Novak, LPP, Feigao and etc. Moreover, ESC is bullet-proof itself with other multiple protection features such as voltage cut-off protection, over-heat protection, throttle signal loss protection, motor blocked protection and splash/dust proof cover. Our customer would breeze through the system setup with the programming card.
Motor Type KV Diameter mm Length without Shaft mm Shaft mm Shaft length
IBL 40/20 2000 42.0 74 5 18.5
RM OHM MAX Volts IO@10V Continuous Watts
0.005 26 2.3A@10V 1350
http://www.thundertiger.com/products-detail.php?id=52&lang=en
ech.Specification
Wheelbase(mm / in.) 320mm(min)/330mm(max)
Weight(g/ lbs.) 3160g
Length(mm / in.) 490mm
Width(mm / in.) 305mm
Height(mm / in.) 180mm
Ground Clearance(mm / in.)
Drive train/Pulley ratio 12.7:1
Motor 2000KV Brushless Motor
olivedsldv
MessagePosté le: 12.09.2014, 21:45:59    Sujet du message: Répondre en citant
Il a l air pas mal se chassis, faut voir sont tarif .
laro
MessagePosté le: 13.09.2014, 03:32:09    Sujet du message: Répondre en citant
370 euros OK!
MessagePosté le: 13.09.2014, 12:42:46    Sujet du message: Répondre en citant
c'est pas jeune ce truc, je pensais pas qu'il était encore en production
pour l'avoir eu je conseil pas, surtout a ce tarif
rasta34
MessagePosté le: 13.09.2014, 18:02:29    Sujet du message: Répondre en citant
Laughing OK!
Y love Tokyo
