simonSG Elite
frikan Expert**
Posté le: 27.02.2014, 12:49:21 Sujet du message: |
Bon weekend en perspective  _________________ 6MIK.Arrow..Exsen.
Z1.Forfaster.byron. |
kistof Expert**
Inscrit le: 16/11/2004 Messages: 624 Localisation: Bayonne
Posté le: 27.02.2014, 13:21:02 Sujet du message: |
woouuuu 21 en voitures a piles...
si quelqu un pouvait faire un petit topo sur le matos utilisé en elec..ce serait super cool....
merci d avance _________________ la lampe torche, le PQ aussi.
Posté le: 27.02.2014, 13:35:45 Sujet du message: |
| nesquik a écrit: | c'est quoi le plus du nouveau Red's  |
bah ,la buse rouge bien sur  |
simonSG Elite
Posté le: 27.02.2014, 14:01:28 Sujet du message: |
| traxxmanfather a écrit: | | nesquik a écrit: | c'est quoi le plus du nouveau Red's  |
Tiens pour les buses qui sauraient lire l'anglais
The new M7 WorldCup, represents the state-of-the-art of 3.5 cc 1/8 On-road racing engine class. The new engine offers the most advanced technologies to ensure the best performance and reliability. These are the main features of WC-Series: new extra long XL stroke engine geometry, back-plate with low friction coating, hybrid ceramic rear ball bearing, balanced crankshaft, all new timing and special tuning by M.Rossi. All these innovations have allowed to increase in particular the power at low and medium RPM preserving the fuel consumption.
Extra long Stroke
The new Extra Long Stroke XL engine geometry gives exceptional power at low-medium RPM, for a greater acceleration. Thanks to the new timing of the 7 ports ABC sleeve , the engine also provides high power at high RPM and low fuel consumption.
Hard coating back-plate
The new back-plate is refined with a special anti-friction hard coating RDC. This coating allows to decrease con-rod/back-plate friction improving engine efficiency and performance.
Team Tuning
Each WC-Series engine component is refined to minimize mechanical friction and improve internal fluid dynamics. Each engine is controlled personally by Mario Rossi, and comes with Quality Control Certificate.
Direct Cooling
The new engine is designed to ensure optimum cooling of the sleeve thanks to a ultra-finned crankcase and a header with "Direct Cooling" technology.
Perfect balance
Our latest generation crankshaft is balanced with two high density material weights. Silicone filling reduces the inertia to rotation. Through the use of special steel and heat treatment, the component is particularly strong and surprisingly reliable.
Lightweight
The new M7 is extremely light! With 310 grams of weight the M7WC is one of the lightest engines in its class. The engine has been designed to save even further weight, maintaining high performance and reliability.
Flat piston
All our 1/8 on road engines use flat pistons matched to a new combustion chamber to ensure high performance at high rpm. Made from a high strength aluminum bar, our piston is a true masterpiece of engineering.
High performance ball bearings
The engine comes with all Swiss Made ball bearings. The new steel-ceramic hybrid rear bearing ensure longer life and low friction at high temperatures.
Composite carburetor
The composite technology provides extreme carburetion stability. Single adjustment minimum needle facilitating the engine carburetion to achieve high performance. The carburetor is subjected to the most strict quality control to ensure maximum reliability. _________________ SimonSG
F@ck fuel economy.
Le droit de rouler vite
Posté le: 27.02.2014, 14:21:35 Sujet du message: |
hi!
i'm a big one
la extra longue course!
traitement dur du bouchon de carter anti fricton pour la bielle
roulement ceram suisse ,piston plat , vilo traité equilibré + pate
tunning et controle a la" mario"
etc.....
et le carbu cOmposite +les BUSES rouge
pour info red =rouge not raide
en plus si il est raide ,il doit pas (plus) bien tourner
ps: 1 orion jpg c est + raide
tu en a 1 jeff non ?  |
buffalo Expert**
Inscrit le: 19/06/2009 Messages: 580 Localisation: france
Posté le: 27.02.2014, 15:02:02 Sujet du message: |
bien entendu
tout jpg est plus raide meme les jambes  |
crazydriver Elite
Posté le: 27.02.2014, 15:18:22 Sujet du message: |
qui a dit qu'il n'y avait plus que les jambes de raides chez Buffalo ??  _________________
Posté le: 28.02.2014, 11:59:37 Sujet du message: |
hi!
c est séparé dans les stands , les electrons des thermiques
ou vous pouvez vous mettre a coté
(humour aussi c est vendredi mais pas de poisscaille ou kay  |
Sigma Elite
Posté le: 01.03.2014, 07:22:16 Sujet du message: |
Je suis content de voir autant d'inscrits pour cette première manche qui j'espère se passera avec le soleil et une bonne ambiance.
Affûtez vos châssis, changez les piles du chrono.... et surtout n'oubliez pas votre radio !!!!
A vendredi
François |
simonSG Elite
Posté le: 01.03.2014, 12:12:35 Sujet du message: |
| Sigma a écrit: | Je suis content de voir autant d'inscrits pour cette première manche qui j'espère se passera avec le soleil et une bonne ambiance.
A vendredi
François |
Tu l'as retrouver ton chrono et le sifflet aussi  _________________ SimonSG
F@ck fuel economy.
Sigma Elite
Posté le: 01.03.2014, 12:27:34 Sujet du message: |
| simonSG a écrit: | | Sigma a écrit: | Je suis content de voir autant d'inscrits pour cette première manche qui j'espère se passera avec le soleil et une bonne ambiance.
A vendredi
François |
Tu l'as retrouver ton chrono et le sifflet aussi  |
Gros investissement en ce début de saison, sifflet et chrono neufs !!!
par contre s'il ne s'arrête pas ai pris rdv chez Audika !!!
Suis paré pour les longues courses.... |
simonSG Elite
Posté le: 01.03.2014, 13:32:17 Sujet du message: |
ah ah ah ok à bientôt mon ami
On va se marrer comme d'hab  _________________ SimonSG
F@ck fuel economy.
billtornade Ligue
Posté le: 05.03.2014, 18:00:58 Sujet du message: |
Cette 1ère manche de CF s'annonce ensoleillée ! Top  _________________ http://www.modelespace.com/ |
daffy Découverte
Posté le: 09.03.2014, 14:56:53 Sujet du message: |
déçu de pa être la ba pour rouler avec mais pot mais suit a un accident de travail impossible de rouler pour moi pendant 3 a 6 mois |
chris_86 Découverte
Inscrit le: 07/05/2009 Messages: 85 Localisation: Poitiers
Posté le: 09.03.2014, 18:46:19 Sujet du message: |
Voici le classement de la finale thermique après 45min :
Le podium :
Le podium en brushless :
chris_86 Découverte
Posté le: 09.03.2014, 20:26:13 Sujet du message: |
Pole et victoire pour Romain Delaunay :
Christophe Bataillard lors de la finale en route pour la 2ème place:
Et Stephan Nicaud pour compléter le podium :
chris_86 Découverte
Posté le: 09.03.2014, 20:35:10 Sujet du message: |
Le départ de la finale thermique :
Le poleman en tête dès le 1er virage :
t16 Expert*
Posté le: 09.03.2014, 20:56:40 Sujet du message: |
Et toujours la merveilleuse Mimi pour aider son mari, et ça date pas d'aujourd'hui, tiens me rapelle que mimi, l'a été à la féfé ...
En tout cas bravo à Mimi et Serge
t16 |
chris_86 Découverte
Posté le: 09.03.2014, 22:10:35 Sujet du message: |
Pour finir, quelques voitures à piles en action
axl Elite
fcjm78 Elite
Inscrit le: 19/09/2008 Messages: 1640 Localisation: la queue les yvelines
Posté le: 10.03.2014, 11:32:23 Sujet du message: |
est ce qu'il y a des photos des classique a piles sans caro?
superbe temps pour une premiere _________________ Ludovic Morlot 17050
30°north 1/5 short course
zenoah 29cc stock
spf froid et climatisation |
billtornade Ligue
simonSG Elite
simonSG Elite
simonSG Elite
Jacky38 Découverte
Posté le: 17.03.2014, 17:10:22 Sujet du message: |
Bonsoir
Quelqu'un a t'il des photos des Brushless ?
Jacky |
fc10 Expert*
Posté le: 18.03.2014, 07:36:38 Sujet du message: |
sur le site de modelespace a la suite des photos du thermique _________________ mugen labema falcon
6mik top options
le frein c'est pour les laches |
