Nico91 Expert**
![](https://scontent-a-fra.xx.fbcdn.net/hphotos-xpa1/v/t1.0-9/13994_688973251218506_2315091119568871120_n.jpg?oh=8eb4838a30f43cf144db690d466f769e&oe=54FDE8CA)
Inscrit le: 01/03/2009 Messages: 556 Localisation: 91, LIGUE 2 PMC
Posté le: 06.12.2013, 16:39:49 Sujet du message: [Post Officiel] VRC PRO - Sortie du 1/8TT le 18 décembre |
Bonjour à tous, c'est maintenant officiel le 1/8 buggy sortira sur Vrc le 18 décembre, pour nous peut etre le 19 decembre.
Voici un des report de David Ronnefalk: (2013 European Champion 1:8 buggy and IFMAR 1:10 buggy finalist)
"I was able to run almost 2h tonight I decided to stick with one track for the night and I chose Padova as I can feel what happens to the car very well there. I tested tons of stuff but wanted to stick to the things that change the cars behavior most. So I played around a lot with diffs, camber, steering lock, wheels, brakes etc. What I came up with was a really really good base I think, at least for Padova..
I have read all posts here and I don´t think all of you (those who says that the car is not good enough for release) have tested enough with the setup.. If you feel the car is not good right now it is all about the setup, for sure. I know the default setup isn't the best one that's why I decided to test all I was thinking to make it better. The car is really good and I think it is ready for release for sure. Of course there is always stuff you can improve but that is same with everything!!
So back to where I was. So for Padova you need a really stable and consistent car which needs to be easy to drive. So from my knowledge I made everything to it as I would have done to my own car IRL. I attached a setup so you all can check what your thoughts are of it. I think this one could be a good base setup! I don't need to write down all changes I made but I liked 5/5/9 in the diffs with 31 degrees in steering lock. I also went with the "MR" wheels as I feel the track is very sensitive and then you won´t need "HR" wheels.. I guess you can check it out by yourself. Tell me if you find something that can be improved. Also please test it on other tracks than just Padova. I will do this tomorrow. Anyway, I was running consistent 34 second laps with it and my best were 34.238 I think So thats the time to beat!!! Hahahha
Once again the car is for sure good enough for release!"
Et voici la trad pour ceux qui sont fachés avec l'anglais :
David Ronnefalk : (2013 Champion d'Europe 01:08 buggy et IFMAR 01h10 poussette finaliste )
«J'étais capable de courir presque 2h ce soir J'ai décidé de s'en tenir à une piste pour la nuit et j'ai choisi Padova que je peux sentir ce qui se passe à la voiture très bien là-bas. J'ai testé des tonnes de trucs mais je voulais m'en tenir aux choses qui modifient le comportement de la plupart des voitures . J'ai donc joué un peu beaucoup avec les diffs , carrossage , barres anti roulies , roues , freins , etc Qu'est-ce que je suis venu avec était un vraiment très bon point de départ , je pense , au moins pour Padoue ..
J'ai lu tous les messages ici et je ne pense pas que vous tous ( ceux qui dit que la voiture n'est pas assez bon pour la libération ) ont suffisamment testé avec la configuration .. Si vous vous sentez la voiture n'est pas bonne en ce moment il est tout au sujet de l'installation , pour sûr . Je sais que la configuration par défaut n'est pas le meilleur , c'est pourquoi j'ai décidé de tester tout ce que je pensais de faire mieux . La voiture est vraiment bonne et je pense qu'il est prêt pour la mise en sûr . Bien sûr, il est toujours des choses que vous pouvez améliorer , mais c'est même avec tout !
Donc, retour à l'endroit où je me trouvais. Donc, pour Padova vous avez besoin d'une voiture vraiment stable et cohérent qui doit être facile à conduire . Donc, à partir de ma connaissance, je fait tout pour elle comme je l'aurais fait à ma propre voiture . J'ai attaché une configuration de sorte que vous pouvez vérifier tout ce que vous pensez de lui. Je pense que celui-ci pourrait être une bonne configuration de base ! Je n'ai pas besoin d'écrire tous les changements que j'ai faits , mais j'ai aimé 5/5/9 dans les diffs de 31 degrés dans le blocage de direction . Je suis aussi allé avec les roues " MR " Je me sens comme la piste est très sensible et vous n'aurez pas besoin de roues " RH " .. Je suppose que vous pouvez le vérifier par vous-même . Dites-moi si vous trouvez quelque chose qui peut être amélioré . Aussi s'il vous plaît tester sur d'autres pistes que juste Padova . Je vais le faire demain. Quoi qu'il en soit , je courais cohérentes 34 secondes tours avec elle et mon meilleur devais 34,238 je pense donc c'est le temps à battre ! hahahha
Une fois de plus la voiture est sûre pour la sortie! "[/img] _________________ Vrc Pro
Nicolas Loriot |
Nico91 Expert**
Posté le: 06.12.2013, 16:42:42 Sujet du message: |
Nicolas Loriot |
carino Ligue
Posté le: 06.12.2013, 18:34:42 Sujet du message: |
salut nico, sait on quel châssis, moteurs, roues ... seront disponibles ?
y aura t il un châssis spec disponible pour la version free ? |
Nico91 Expert**
Posté le: 06.12.2013, 19:30:27 Sujet du message: |
Salut, pour le moment il n'y aura pas de spec ; )
Sinon au niveau des composant la liste sera bientot dévoilé et des partenariats sont en cours, ils ont déja signé avec Aka,Proline et Bittydesign ; ) _________________ Vrc Pro
Nicolas Loriot |
Franky_4X2 Elite
![](modules/Forums/images/avatars/gallery/0380.gif)
Posté le: 13.12.2013, 20:01:55 Sujet du message: |
J-5 ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) _________________ 2024 retour au KAT2
GT8 : XB8-Teckno / SCTPRO 120A + TORO 2350KV + Krypton 7200mAh. |
Mamare Ligue
![](modules/Forums/images/avatars/gallery/0775.gif)
Posté le: 13.12.2013, 20:33:12 Sujet du message: |
Ah là là , je suis comme un fou , déjà la grosse MAJ d'aujourd'hui est enorme ![OK!](modules/Forums/images/smiles/ok.gif) |
mimili Découverte
Posté le: 13.12.2013, 20:35:55 Sujet du message: |
elle rajoute quoi cette maj?? |
Mamare Ligue
Posté le: 13.12.2013, 21:49:54 Sujet du message: |
Beh honnêtement je viens de la tester plus profondement et je dois dire que je suis tres deçu pour ce qui est du SC , je ne reconnais plus du tout le comportement du chassis , y'a trop de grip , c'est limite gerable mais surtout sur la piste sur laquelle j'etais le plus performant je n'ai plus moyen de tourner dans les memes temps qu'avant ni à etre regulier , moi qui est pris l'abonnement illimité je commence à regretter !!! |
mimili Découverte
Posté le: 13.12.2013, 22:10:47 Sujet du message: |
ba je viens de faire la maj ya une heures et tester
alors sur la piste de la silver dollar je ne pouvait pas descendre sous les 34.5 s et la grace à ce comportement certes difficile j'ai dais mon new record à 32.4s bon david ronnefalk me met encore 2 secondes mais bon ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
Mamare Ligue
Posté le: 13.12.2013, 22:22:44 Sujet du message: |
Apparement tout le monde descend ses chronos sur la silver dollar , honnêtement ça m'a soualé et j'ai pas testé sur cette piste , je me suis contenté de rester sur la piste que je connais le mieux . J'ai tellement étais surpris par le comportement du châssis que j'ai préféré arrêter ! |
Franky_4X2 Elite
Posté le: 13.12.2013, 23:09:27 Sujet du message: |
idem 7 sec sur mon meilleur chrono... du coup j'suis classé 31° en 13.5t sur la Silver Dollar!!
j'la trouve pas mal cette MAJ ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) _________________ 2024 retour au KAT2
mimili Découverte
Posté le: 13.12.2013, 23:20:57 Sujet du message: |
Mais bon pour moi ce jeux ne peus pas être une base pour ce compare aux meilleurs top pilotes ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Nico91 Expert**
Posté le: 14.12.2013, 09:01:03 Sujet du message: |
Salut je ne comprend vraiment plus rien, tous le monde se plaint qu'il n'y a pas assez de "grip" alors ils changent les parametres des pneus pour que le sc glisse moins et personne n'est content. ( En france seulement d'ailleur )
Depuis la mise à jour tous les ricains sont super content.
Et au faite petite info aucun grip n'a etait augmenté.
C'est juste la réaction du pneu par rapport au sol, aprés bien sur il faut adapter son setup _________________ Vrc Pro
Nicolas Loriot |
quiks56 Elite
![](https://fr-fr.facebook.com/256711123007/photos/10152953064623008/)
Inscrit le: 06/05/2007 Messages: 1369 Localisation: erdeven 56
Posté le: 14.12.2013, 09:09:23 Sujet du message: |
C est ça le français jamais Content !!!!!! _________________ HBRACING.REEDS.SAVOX.6MIK..LA TEAM MORAT |
Nico91 Expert**
Posté le: 14.12.2013, 09:27:12 Sujet du message: |
Mdr oui ; ) _________________ Vrc Pro
Nicolas Loriot |
Franky_4X2 Elite
Posté le: 14.12.2013, 10:58:35 Sujet du message: |
Ah le français qui râle... en même temps mamare y en a marre c'est bien trouvé
Quand je vois comment la France fait rêver à travers le monde je me demande si les étrangers sont au courant de cet aspect de la culture française... A mon avis cela en dégouterait plus d'un!!!
mimili a écrit: | Mais bon pour moi ce jeux ne peus pas être une base pour ce compare aux meilleurs top pilotes ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Ronnefalk me met 4sec au tour sur la Silver Dollar.
Du coup je ne m’inquiète pas sur le fait que dans la réalité il m'en mette autant... voire plus peut être!!
Pour faire plus local, des gars comme Delcourt et Rosetti sont eux aussi meilleurs que moi en réalité et le sont également sur VRCPro...
PS: au fait j'oubliais J-4 ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ 2024 retour au KAT2
carino Ligue
Posté le: 14.12.2013, 11:38:55 Sujet du message: |
moi monsieur je suis très content de cette MAJ. |
Mdp177 Champion du monde
![](modules/Forums/images/avatars/gallery/1033.gif)
Posté le: 14.12.2013, 12:58:00 Sujet du message: |
En même temps pour la silver dollar , l'année derniere , quand je roulais que sur celle la , j'étais en 32 regulier , ils ont fait une mise a jour impossible de passé sous les 34 voir 35 , donc la s'ils ont modifié c'est pas plus mal ! |
Mamare Ligue
Posté le: 14.12.2013, 15:36:13 Sujet du message: |
Je pense que le jour ou on pourra exprimer son avis librement sur ce forum sans se faire bousiller on aura vraiment avancé !!!!! Marre de se faire deglinguer dés qu'on exprime son point de vue !!! Supprimez mon compte si ça vous plait pas mais on reste dans un pays de liberté !!! Tain comme ils me gonflent tous ( tjrs les memes ) !!!!!!!!!! ![Hors Sujet](modules/Forums/images/smiles/hors_sujet.gif) |
Mamare Ligue
Posté le: 14.12.2013, 15:42:19 Sujet du message: |
Nico91 a écrit: | Salut je ne comprend vraiment plus rien, tous le monde se plaint qu'il n'y a pas assez de "grip" alors ils changent les parametres des pneus pour que le sc glisse moins et personne n'est content. ( En france seulement d'ailleur )
C'est juste la réaction du pneu par rapport au sol, aprés bien sur il faut adapter son setup |
T'a raison zozo , y'a que les français qui se plaignent : Bart Banach
yesterday [18:04]
Reply | Mark offensive
Hi
After update I had a go in SC and I found running on silver dollar feel like running on tarmac. I ménage do 32 where before my fastest lap was 34. I think level of grip is not set right |
Nico91 Expert**
Posté le: 14.12.2013, 16:12:14 Sujet du message: |
Ok ok, ce n'est que mon avis, aprés, la tu donne ton avis pas de prob. Je répondais juste. Tu peut dire ce que tu veut, HEURESEMENT D AILLEURS _________________ Vrc Pro
Nicolas Loriot |
Nico91 Expert**
Posté le: 14.12.2013, 19:12:43 Sujet du message: |
Voici un petit message posté par Konings Jean Yves aujourd'hui à 17:21
"et aussi faudrai que quelqu'un leur explique que un 4wd ca part pas du cul comme un saucisse a chaque virage .... car la je sors de ma saison de championnat je reprend vrc et pu... ca arien avoir avec la réalité niveau grip" _________________ Vrc Pro
Nicolas Loriot |
StephMP7.5 Expert**
![](https://img4.hostingpics.net/pics/177077DSCF3429.jpg)
Inscrit le: 05/01/2006 Messages: 794 Localisation: au circuit, une radio à la main
Posté le: 15.12.2013, 16:00:49 Sujet du message: |
Pour ma part, je suis très satisfait de la mise à jour. Je trouve que les réactions de la voiture sur les appuis sont bien plus constantes que précédemment.
Ca doit être un boulot monstre à programmer, et toute avancée mérite d'être soulignée ! ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Stephen VERMERSCH |
Nico91 Expert**
Posté le: 15.12.2013, 16:09:57 Sujet du message: |
Oui effectivement !! Enormement de travail _________________ Vrc Pro
Nicolas Loriot |
mrlasdu89 Expert**
![](https://a2tech.free.fr/divers/moi.jpg)
Posté le: 16.12.2013, 07:58:47 Sujet du message: |
hello
bon, tentative de changer la date du système au cas ou..........
ben....ils m'ont fait remarquer que l'heure de mon pc etait différente de celle de leurs serveurs.....
au moins j'aurais essayé !!!!
donc en gros, ça sert à rien, ce sera pour mercredi et pas avant
![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
Nico91 Expert**
Posté le: 16.12.2013, 08:22:43 Sujet du message: |
Salut mdr, effectivement bonne tentative ))
Mais les fichiers ne sont pas sur le serveur de l'upload
Mais dés qu'il les mettra tous le monde l'aura.
C'est pour cela que le changement de la date ne marche pas ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Vrc Pro
Nicolas Loriot |
Posté le: 16.12.2013, 08:38:23 Sujet du message: |
grosso modo , ça va marcher comment ?
Si on est deja abonné ( pour 3 mois ) , y'aura juste une mise a jour est tout sera dispo ? ( sauf biensure les pistes qu'il faudra acheter surement . ) |
Kartman Expert**
![](modules/Forums/images/avatars/0693.gif)
Posté le: 16.12.2013, 08:57:15 Sujet du message: |
Toujours pas possible sur MAC ? |
mrlasdu89 Expert**
Posté le: 16.12.2013, 08:59:41 Sujet du message: |
Citation: | Salut mdr, effectivement bonne tentative Smile))
Mais les fichiers ne sont pas sur le serveur de l'upload Wink
C'est pour cela que le changement de la date ne marche pas Wink
_________________ |
vu que j'ai eu une mega mise à jour samedi......je m'étais dit que.......
BEN NON !!!
SebLeLoch Elite
![](modules/Forums/images/avatars/Perso/FranckyGoes_logo_mugen2008.gif)
Inscrit le: 01/02/2010 Messages: 1590 Localisation: Nantes
Posté le: 16.12.2013, 09:04:11 Sujet du message: |
Je trouve aussi la nouvelle mise à jour super, beaucoup de grip à certains endroits c'est vrai mais rien à voir avec notre vraie piste TT en plein de mois de juillet quand elle est dur comme du béton et que c'est le toit assurer si on attaque trop.
Et puis le grip on peut décider de le descendre, ce qui est une option sympa car en TT en vrai on n'a pas non plus le même grip tout le temps. Dans une saison "club" ça permettrai de rouler dans des conditions différentes... _________________ F1VE 1/5 Proto "Team GMP F1"
MBX7R - Werks - SP/AKA/James
Drone racer 250 RCX - CC3D |
