RCmag :: Voir le sujet - Kit HotBodies D812
Kit HotBodies D812 Aller à la page 1, 2, 3 ... 9, 10, 11  Suivante
philippe27
MessagePosté le: 15.01.2013, 21:03:27    Sujet du message: Kit HotBodies D812 Répondre en citant
The D812 is completely updated with the latest input from HB team drivers Ty Tessmann and Atsushi Hara - from the front to rear, the car is fully optimized for top-level racing!
The D812 chassis is constructed from tough and lightweight aluminum, and is designed to be narrow with all of its components sitting as low as possible. The narrowness and low CG allows for the best handling properites, which when combined with World-class suspension design, gives the HB racing team the unfair advantage on the track.
A sturdy C-hub style front suspension handles things up front, with aluminum uprights, graphite steering knuckle arms and steel turnbuckles. Aluminum uprights and steel turnbuckles take care of getting the power to the ground at the rear end.
The shocks are long-stroke versions of the World Champion HB Big Bore shocks, which feature aluminum bodies with threaded bodies and threaded top and bottom caps. Controlling the chassis roll at each end of the car are conventional wire sway bars.
Features Summary
Centralized chassis weight for superior handling
Monocoque style suspension arms for strength, stiffness, and ease of cleaning
HB Big Bore threaded aluminium shocks for excellent suspension control
Race-optimized steering
Long stroke shocks for long suspension travel
Lightweight drivetrain gears have less rotational mass for quicker acceleration
Lightweight aluminum axles
Graphite steering knuckle arms
One-piece engine mount for easy engine installation without resetting gear mesh
Aluminum front and rear shock towers
CVD boots to retain grease in axles and keep dirt out
Adjustable hinge pin heights, kickup, and anti-squat angle
Adjustable rear toe-in (inboard and outboard)
Steel skid plate in chassis to extend chassis life
Aluminum front caster blocks
Aluminum rear hub carriers
One-piece radio tray
Fuel clunk for continuous fuel pick-up even when upside down
Low-profile air filter
Front and rear anti-roll bars
Threaded outer hinge pins
Steel turnbuckles
2012 ROAR National Champion!
HB D812 Spec:
Length: 480mm
Width: 310mm
Wheelbase: 327mm (adjustable)
What You Need:
.21 size racing buggy engine
Tuned exhaust pipe and header
Tires
Inserts
2-channel radio system with 2 servos, receiver and battery
Fuel
Fuel bottle
Receiver battery pack
Glow igniter
Starter box
Polycarbonate paint
http://www.hotbodiesonline.com/kit.php?partNo=109428&lang=en
[/img]
Yeho
MessagePosté le: 15.01.2013, 23:30:22    Sujet du message: Répondre en citant
Est-ce que quelqu'un connait son poids? Je le trouve nulle part, étrange pour un châssis de compétition Mad
laro
MessagePosté le: 16.01.2013, 14:03:59    Sujet du message: Répondre en citant
Question toujours pas de prix ni de date de sortie Rolling Eyes
speedy2
MessagePosté le: 16.01.2013, 15:01:29    Sujet du message: Répondre en citant
519.00 usd
le 13 fevrier date de sortie officiel
laro
MessagePosté le: 16.01.2013, 15:10:06    Sujet du message: Répondre en citant
speedy 2 OK!
philippe27
MessagePosté le: 18.01.2013, 00:02:25    Sujet du message: Répondre en citant
http://www.hbeurope.com/pdfs/setups/109428_D812_%28Blank_Setup%29.pdf
http://www.hbeurope.com/pdfs/setups/109428_D812_%28Standard_Setup%29.pdf
http://www.hpieurope.com/manuals/pdf/109428.pdf
http://www.hpieurope.com/kit-info.php?lang=en&partNo=109428
speedy2
MessagePosté le: 02.02.2013, 23:22:11    Sujet du message: Répondre en citant
qqs uns de livrer déjà... sansdoute aux membres Team hors Europe
mais ils sont en route depuis le 24/01
j-j-g
MessagePosté le: 03.02.2013, 12:36:49    Sujet du message: Répondre en citant
Very Happy super
boysdontcry
MessagePosté le: 04.02.2013, 13:23:47    Sujet du message: Répondre en citant
Hot Bodies Infantry team, ils ont reçu la voiture. Celà ne va donc pas tarder pour les clients normaux. Razz
speedy2
MessagePosté le: 08.02.2013, 16:11:23    Sujet du message: Répondre en citant
disponible en usa
laro
MessagePosté le: 08.02.2013, 17:20:02    Sujet du message: Répondre en citant
Question pour la france toujours pas de precommande Rolling Eyes
speedy2
MessagePosté le: 12.02.2013, 16:20:26    Sujet du message: Répondre en citant
les pièces D8 envers les D812, triangles et corps de shocks plus long
laro
MessagePosté le: 12.02.2013, 19:15:50    Sujet du message: Répondre en citant
en precommande au usa 388 euros OK!
MessagePosté le: 12.02.2013, 20:28:31    Sujet du message: Répondre en citant
prix bien placer
speedy2
MessagePosté le: 13.02.2013, 15:03:20    Sujet du message: Répondre en citant
Double4
MessagePosté le: 13.02.2013, 15:09:30    Sujet du message: Répondre en citant
HyperRC a écrit:
prix bien placer
Plus les frais de port et éventuellement les frais de douane .......
j-j-g
MessagePosté le: 13.02.2013, 17:17:55    Sujet du message: Répondre en citant
Very Happy enfin une bonne nouvelle
speedy2
MessagePosté le: 14.02.2013, 10:49:21    Sujet du message: Répondre en citant
Yeho
MessagePosté le: 14.02.2013, 11:27:00    Sujet du message: Répondre en citant
Et personne l'a encore pesé? Mad
laro
MessagePosté le: 14.02.2013, 17:17:37    Sujet du message: Répondre en citant
speedy2 a écrit:
platine radio a la Ty Tessman Question
laro
MessagePosté le: 14.02.2013, 18:15:11    Sujet du message: Répondre en citant
Very Happy dispo de suite au usa a 524 usd +59usd de livraison total en euros 433 euros
Double4
MessagePosté le: 14.02.2013, 18:24:06    Sujet du message: Répondre en citant
+ les frais de douane à l'arrivée, selon le facteur chance Question
speedy2
MessagePosté le: 14.02.2013, 21:39:25    Sujet du message: Répondre en citant
quel est le prix en europe ?
au voir le prix us, çà devrait être au moins 485 euro
laro
MessagePosté le: 14.02.2013, 22:00:28    Sujet du message: Répondre en citant
j'ai contacté plusieurs personnes et plusieurs magasins en france personne ne ces même Richard Colardelle ne ces pas Evil or Very Mad
Double4
MessagePosté le: 15.02.2013, 10:02:03    Sujet du message: Répondre en citant
Normal : priorité au marché "loisir" et dans l'immédiat au succès de la 3 ème édition des 24 heures "BLITZ HPI" au THOR les 23 et 24 février Smile .
laro
MessagePosté le: 15.02.2013, 10:22:52    Sujet du message: Répondre en citant
Rolling Eyes Après on dit la France va mal maintenant je comprends pourquoi
laro
MessagePosté le: 16.02.2013, 12:21:33    Sujet du message: Répondre en citant
le magasin aux usa ma contacter pour me dire que le kit sera dispos de nouveau au mois d'avril aux usa donc en France Question mauvaise nouvelle Sad
Yeho
MessagePosté le: 16.02.2013, 12:35:55    Sujet du message: Répondre en citant
Je viens de tomber sur la page d'un magasin français en ligne qui propose le D812 en prévente... 599,99€, ça calme Laughing
laro
MessagePosté le: 16.02.2013, 13:07:59    Sujet du message: Répondre en citant
Je viens de tomber sur la page d'un magasin espagnol en ligne qui propose le D812 en vente a 540 euros fdp gratuit
MessagePosté le: 16.02.2013, 13:32:53    Sujet du message: Répondre en citant
Faut en profiter, pas de douane avec l'Espagne Wink
Page 1 sur 11
