RCmag :: Voir le sujet - servo Blue Arrow Magnetic Induction Brushless
philippe27
MessagePosté le: 23.12.2011, 18:51:55    Sujet du message: servo Blue Arrow Magnetic Induction Brushless Répondre en citant
servo Blue Arrow
Magnetic Induction Brushless Motor
Control System: PWM Pulse Width Control
Processor: Digital IC
Required Pulse: 3 to 5 V Peak to Peak Square Wave
Working frequence: 1500 μs /333 Hz
Rotation angle sensor: MAGNETIC INDUCTION
Rotation: Left Rotation: 46, Right Rotation: 46
Voltage: 4.5V to 7.4V
Temperature Range: -20℃ to 60℃
Driver Type: MOSFET
Operating Angle: 45 Deg. one side pulse traveling 400μs
Direction: Clockwise/Pulse Traveling 900μs-2100μs
Pulse Width Scope: 900-2100μs
Neutral pulse: 1500μs
Resolation: Minimum resolution:0.088°/0.9μs
Maximum resolution:0.350°/4μs
Rotational speed of magnet: Maximum 600RPM (r / min)
Magnetic offset: ±10mT
Magnetic input field amplitude: 45 to 75mT
Speed:(No-load ): 0.16sec/ 60° @ 6.0V
0.13sec/ 60° @ 7.4V
Torque:(Stall Full load): 11.60 kg . cm @ 6.0V
15.00 kg . cm @ 7.4V
Idle Current: <0.05 A/ 6.0V <0.05 A/ 7.4V
Running Current: <0.10 A/ 6.0V <0.20 A/ 7.4V
Stall Current: 1.5 A/ 6.0V 2.0 A/ 7.4V
Motor Type: Brushless Motor
Bearings: 3 Ball Bearing
Bearing Type: MR74 (4mmX7mmX2mm)
MR106 (6mmX10mmX2.5mm)
MR06ZZ (6mmX10mmX3mm)
Gear Material: Titanium Gear
Servo case: (Aluminum Radiator)Metal Center
Plug: "J" type
Connector Wire Length: 300.00 mm
Connector Wire SPEC: OD1.4mm/60 x 0.08mm 3p x 300mm "J" type
Weight: 56.40 g
Dimensions (L x W x H): 40.00*20.00*37.50 mm
http://www.ltair.com/index.php?route=product/category&path=20
autres
http://www.ltair.com/index.php?route=product/category&path=35
http://www.ltair.com/index.php?route=product/category&path=18
http://www.ltair.com/index.php?route=product/category&path=25
MessagePosté le: 23.12.2011, 19:42:33    Sujet du message: Répondre en citant
cellofane
MessagePosté le: 23.12.2011, 20:12:29    Sujet du message: Répondre en citant
quelqu'un à une idée de comment le servo retrouve son "neutre"? Car le codeur permet de connaitre l'angle de déplacement du servo mais si le palonnier est bougé pendant que le servo est hors tension?
a++ et merci d'avance de la réponse
CELLOFANE le plastique qui t'emballe!!!
C'est pas parce qu'on a des freins qu'il faut s'en servir!!!
Mugen MBX6eu,Racer Sport 2.4Ghz T2M,Novarossi P4BTT et résonateur 9901.
Mumuch
MessagePosté le: 24.12.2011, 11:01:10    Sujet du message: Répondre en citant
Voici un peu de lecture qui t'expliquera le fonctionnement des codeurs rotatif magnétique utilisant l'effet Hall Wink
http://www.mesures.com/archives/764soleffetHall.pdf
Référent Seine Maritime
PP
MessagePosté le: 24.12.2011, 11:03:06    Sujet du message: Répondre en citant
Les deux philippe vous auriez une adresse en MP pour un mags qui les vend?
Merki,
Philippe
Sponsos: Moi, Me, Yo, Ich, Me...
Horizon Hobby/ TLR
Top options
Wartelle Shop
Sylveris RC
alien_life_form
MessagePosté le: 24.12.2011, 12:23:50    Sujet du message: Répondre en citant
Voilà des servos qui devrait tenir au moins 10ans... avec des kit pignons
Seul bémol de la techno : l'info position n'est pas disponible instantanément. Espérons que cela restera suffisamment rapide par rapport aux perfos vitesse précision attendu sur un servo haut de gamme.
En tout cas si toutes les fiches techniques de servo étaient aussi détaillées on choisirait moins ses équipements radio "au hazard"
cellofane
MessagePosté le: 24.12.2011, 12:25:43    Sujet du message: Répondre en citant
Merci pour la lecture Mumuch,je commence à comprendre car mes cours de première année de Science de l'Ingénieur au lycée ne me suffisaient pas.
a++
