RCmag :: Voir le sujet - RC8.2 Factory Team.
RC8.2 Factory Team. Aller à la page 1, 2  Suivante
MessagePosté le: 20.07.2011, 05:51:45    Sujet du message: RC8.2 Factory Team. Répondre en citant
=> RCnews.fr
quiks56
MessagePosté le: 20.07.2011, 07:57:10    Sujet du message: Répondre en citant
Factory Team 3mm lengthened 7075 hard-anodized chassis
- Newly designed suspension arms
- Factory Team 16mm “Big Bore” hard-anodized threaded shocks
- Factory Team 5mm 7075 aluminum low-CG shock towers
- Factory Team 7075 blue aluminum lower suspension mounts
- Factory Team 7075 blue aluminum steering knuckles
- Factory Team 7075 aluminum axles and center drives
- Factory Team 7075 blue aluminum one-piece top plate
- Factory Team lightweight spur and ring gears
- Factory Team lightweight diff outdrives
- Factory Team aluminum steering posts
- CVA boots on center and rear drive joints
- Heatsink brake rotors front and rear
- New low center-of-gravity wing mount
- JConcepts Punisher Body and Illuzion wing included
- Molded composite radio tray includes optional forward-placement
- battery box for increased steering
- Molded composite front and rear chassis braces
- Tough steel-alloy shock standoffs
- Factory Team 83mm “big” wheels included
- Aluminum clutch shoes
- 4.30:1 ratio gearboxes for maximum punch
- Caster blocks adjust 14, 16, or 18 degrees with molded inserts
- 3.5mm light CVA drivetrain with full ball bearings
- Factory Team shock and differential fluids included
- Mud guards
HBRACING.REEDS.SAVOX.6MIK..LA TEAM MORAT
simonSG
MessagePosté le: 20.07.2011, 10:30:45    Sujet du message: Répondre en citant
Looks good OK!
SimonSG
F@ck fuel economy.
Le droit de rouler vite
Sylveris
MessagePosté le: 20.07.2011, 10:37:50    Sujet du message: Répondre en citant
Salut à tous,
Et bien voilà ! On retrouve toutes les améliorations avec le retour des pièces permettant un gain de poids, les sorties de diffs, les supports de sauve servo...
Cette fois-ci c'est bien plus sérieux que la vulgaire tentative que d'essayer de nous vendre un kit "bidon" de conversion, notamment pour les triangles taillés au dremel !
Tous les défauts du premier 1/8 de Associated, surtout après le "B", semblent être gommés, sauf le pare-choc avant, toujours gênant pour changer de BAR ! Maintenant beaucoup de choses vont être "incompatibles" avec le "B", je pense aux barres anti-roulis... est-ce que cela vaut le coup de convertir son "B" en "8.2" ? Quand on a changé son châssis, ses supports amortos, son support aileron, ses triangles ( qu'on a souvent en double dans la caisse ), que fait-on de toutes ces pièces en rab ? Mieux vaut peut-être attendre et racheter un 8.2 ?
Bye !
Options SYLVERIS RC :
www.sylveris-rc.fr
Sylveris
MessagePosté le: 20.07.2011, 10:51:30    Sujet du message: Répondre en citant
En fait beaucoup de choses ont changé, tout est dans le détail, là on voit les vis qui maintiennent les goupilles des Hex, désormais plus grosses... mais aussi la peut-être toute première fois où l'on voit la fusée arrière sur ce point d'ancrage ( haut ), avec un débattement maxi des triangles. D'ailleurs ils avaient déjà corrigé la longueur des noix de diffs arrières, avec une série qui permettait aux cardans de ne plus "frotter" aux noix en débattement maxi.
www.sylveris-rc.fr
cocoracing
MessagePosté le: 21.07.2011, 13:27:02    Sujet du message: Répondre en citant
Ah, enfin un vrai kit. Ca fait quand même moins bricolo que dans :
https://www.rcmag.com/modules.php?name=Forums&file=viewtopic&t=42607
Laughing
On voit des "vrais" nouveaux triangles + un montage plus classique pour les barres anti-roulis qui, je l'espère, devrait mieux vieillir que le montage du RC8B Smile Par contre, le châssis découpé avec la boîte radio qui reste la même que la précédente, ça, c'est pas top ! Perso, j'ai mis le récepteur à l'ar dans une boîte d'accus (la même que celle de l'avant) et ça fait plus aéré, plus propre et on peut même faire sortir le fil d'antenne d'un récepteur spektrum :)
Les fusées av évoluent, dommage qu'il n'en soit pas de même pour les étriers, et surtout les inserts rouges et bleus dans les étriers, c'est une plaie ce truc Sad
Attendons les retours à l'automne mais c'est pas sûr que ça suffise à me convaincre de reste Asso pour l'année prochaine...
StephMP7.5
MessagePosté le: 21.07.2011, 16:42:34    Sujet du message: Répondre en citant
J'ai roulé un peu plus d'une saison avec ce point d'ancrage, sans soucis particulier. Ca passe sur le rc8B, mais il fallait retoucher les triangles sur rc8.
Sinon, beau travail de la part d'asso. Les modifs devraient améliorer le comportement de l'auto.
linker
Présidents
MessagePosté le: 21.07.2011, 20:26:26    Sujet du message: Répondre en citant
Je pense bientot changer de voiture, et j'avoue que le RC8 me botte bien (meme si j'hesite avec d'autres modeles encore). Avez vous des pb pour recevoir les piéces ou pas ?
a+
JM83
MessagePosté le: 21.07.2011, 20:52:04    Sujet du message: Répondre en citant
Pour ma part aucun problème pour commander des pièces Asso. Tu as les mag partenaires de RCMag et d'autres.
linker
Présidents
MessagePosté le: 21.07.2011, 21:03:09    Sujet du message: Répondre en citant
merci Wink
Cela me rappelera ma jeunesse en electrique Mad
vulcain11000
MessagePosté le: 22.07.2011, 09:13:37    Sujet du message: re Répondre en citant
moi,avec c nouveautées sur le chassis,je pense que je vais revenir sur asso.il est superbe Very Happy OK!
Ollive
MessagePosté le: 22.07.2011, 20:11:53    Sujet du message: Répondre en citant
c est vrai qu il est beau, ilsera dispo en france quand?
Sylveris
MessagePosté le: 22.07.2011, 20:24:41    Sujet du message: Répondre en citant
Salut à toi,
je ne crois pas que les triangles arrières du RC8 et du RC8B soient différents, en tout cas il n'y a eu aucun changement de référence. Je n'ai pas de triangle du RC8B donc je ne peux comparer, mais je ne crois pas avoir vu de changement. Du coup je pense que si tu as pu utiliser ce point d'ancrage sans aucune modif, c'est que tu n'utilisais pas le débattement maxi proposé par tes amortos, quels que soient leurs points d'ancrage, ou alors en inversant gauche et droite, les supports d'amortos qui se fixent aux triangles, et encore...
Par contre sans le débattement maxi, c'est en effet possible.
Bye !
www.sylveris-rc.fr
StephMP7.5
MessagePosté le: 22.07.2011, 20:37:10    Sujet du message: Répondre en citant
Salut à toi,
Bye !
La référence n'a effectivement pas changée, mais le renfort à l'extrémité a bel et bien changé, afin de pouvoir utiliser le débattement maxi, même dans cette configuration. Si tu possède ne possède pas les triangle du B, tu peux aisément faire la modif toi-même à l'aide d'une meule Wink
stan93700
Sponsors
MessagePosté le: 22.07.2011, 21:07:59    Sujet du message: Répondre en citant
Elle est prévu en France pour septembre
CAV Viglain
Rc Models Team
Sylveris
MessagePosté le: 23.07.2011, 00:23:45    Sujet du message: Répondre en citant
Alors là, je te remercie de l'info, je n'avais jamais remarqué cela. Cela fait plaisir de voir qu'on est nombreux à aller dans les détails, après tout j'aime bien ce châssis (sauf les jeux dans plein de pièces), manque juste de pouvoir jouer sur la prépondérance. Je pensais faire la modif sur les miens, c'est pour dire, j'ai toujours les premiers triangles de mon RTR ! Il va falloir que je me mette à la page...
Merci.
Bye !
www.sylveris-rc.fr
Frankytwist
MessagePosté le: 07.08.2011, 16:21:14    Sujet du message: Répondre en citant
Qui distribue Associated en France maintenant ?
Ce n'est plus MRC apparement
TT 1/8 Bls: Hong Nor X3S EVO, rocket 4274/1950V2, pneus VP Pro
kerb
MessagePosté le: 07.08.2011, 16:48:17    Sujet du message: Répondre en citant
A priori RMD et il doit etre possible de se servir directement chez CML en Angleterre.
stan93700
Sponsors
MessagePosté le: 07.08.2011, 18:58:55    Sujet du message: Répondre en citant
l'importateur pour la france est CML Distribution
CAV Viglain
Rc Models Team
JM83
MessagePosté le: 07.08.2011, 20:46:04    Sujet du message: Répondre en citant
Racing Model Distribution qui est une petite structure, situé à Marignane, distribue Asso depuis 20 ans. C'est le distributeur historique. Quand Asso a été acheté par Thunder Tiger, MRC étant déjà distributeur Thunder a naturellement pris la carte Asso. Depuis c'est CML (partenaire de RC Mag) situé en Angleterre qui distribue Asso. Mais RMD continue de distribuer Asso. Voilà qui est dit.
Par contre avec la perte de MRC, Asso n'a plus de pilote officiel en France, ce qui est bien dommage, car c'est pour moi le gros point faible du RC8. RMD pour sa part n'a pas les moyens financiers pour sponsoriser d'éventuels pilotes.
Frankytwist
MessagePosté le: 29.09.2011, 20:16:11    Sujet du message: Répondre en citant
Apparement il est disponible à l'étranger
Et en France?
stan93700
Sponsors
MessagePosté le: 29.09.2011, 21:47:30    Sujet du message: Répondre en citant
Oui il est dispo en france
CAV Viglain
Rc Models Team
philippe27
MessagePosté le: 29.09.2011, 21:59:10    Sujet du message: 2011 Thunder Alley Gas Champs Highlights With Ryan Cavalieri Répondre en citant
2011 Thunder Alley Gas Champs Highlights With Ryan Cavalieri & His RC8.2
http://www.youtube.com/watch?v=8WcpAlwKAvY&feature=player_embedded
Metapsycho
MessagePosté le: 29.09.2011, 23:49:57    Sujet du message: Répondre en citant
avec le 808 c'est le retour des morts vivants !
marti07
MessagePosté le: 06.10.2011, 20:00:29    Sujet du message: Répondre en citant
A votre avis cette voiture existera en BL ???
piche34
MessagePosté le: 12.10.2011, 13:44:22    Sujet du message: rc8.2 Répondre en citant
salut j ai recu le mien!! tres belle auto beaucoup de bonne on etait amelioré!! a+
yopromo
MessagePosté le: 12.10.2011, 14:21:27    Sujet du message: Rc8b.2 Répondre en citant
Bonjour piche dit peut tu me dire quel est le poid du chassi complet une foit monter avec moteur servo etc..merci
Etan
MessagePosté le: 12.10.2011, 14:34:45    Sujet du message: Répondre en citant
Sur cml ils parlent de 3,167kg : je suis d'avis que c'est sans le moteur?? Surprised
RC10 WorldCar
www.rc-cmat.fr
piche34
MessagePosté le: 12.10.2011, 15:14:23    Sujet du message: Re: Rc8b.2 Répondre en citant
ok pas de probleme je te fait des que je monte!!
yopromo
MessagePosté le: 12.10.2011, 17:50:17    Sujet du message: Rc8b.2 Répondre en citant
Ok cool merci
