RCmag :: Voir le sujet - Insert de roue type airbag veggoplastrc
RCmag Index du Forum » TT 1/8 technique
philippe27
MessagePosté le: 24.04.2010, 19:25:14    Sujet du message: Insert de roue type airbag veggoplastrc Répondre en citant
http://www.veggoplastrc.com/index.php?option=com_content&view=article&id=76&Itemid=147&lang=en
flo13
MessagePosté le: 24.04.2010, 19:31:13    Sujet du message: Répondre en citant
Le concept a l'air intéressant:
"New AIRBAG inserts available.
AIRBAG is the revolutionary tyre insert developed and produced in Italy. Due to its unique and incredible features, AIRBAG is a must have for all serious racers.
Characteristics:
PERFECTLY BALANCED: just drop'em on and see the difference
ZERO CENTRIFUGATION: it means perfect contact of the tyre with the racing surface for improved traction and optimal steering response
TOTAL CONTROL: less side roll and less tyre wear
ULTRA RESISTANT: won't break as standard foams and don't collect dirt wihich can alter tyre responsiveness
PERFECT MATCH: they fit perfectly on the rim due to exclusive internal pattern
WATER RESISTANT: wash your tires without ani issue
DURABLE: can be used many times with multiple set of tires because they have no degrade
AIRBAG inserts are available in 3 different compounds:
RED: soft compound
YELLOW: medium compound
GREEN: hard compound
AIRBAG inserts are sold in set of 4 of same compound
sqamtech
MessagePosté le: 27.04.2010, 14:46:41    Sujet du message: Répondre en citant
pour le concept OK! OK! Surprisedk:
pour le " zero centrifugation ", même si l'insert ne centrifuge plus, le pneus,lui, il centrifugera toujours...
ils font aussi des jantes et des pneus mais pour ces derniers il y a pas encore de photos.
flo13
MessagePosté le: 19.05.2010, 06:00:18    Sujet du message: Répondre en citant
amontintin
MessagePosté le: 19.05.2010, 08:23:41    Sujet du message: Répondre en citant
j'aimerai bien que notre expert français nous dise ce qu'il en pense....allez seb encore du taff pour toi Laughing Laughing
Poster un nouveau sujet   Répondre au sujet    Haut de page » Accueil » RCmag Index du Forum » TT 1/8 technique Toutes les heures sont au format GMT + 1 Heure
