Seb_BdR Modérateur Champion du monde
Inscrit le: 22/01/2007 Messages: 5105 Localisation: aix en provence
Posté le: 22.04.2010, 21:49:28 Sujet du message: Sac de transport Kyosho |
Bonjour, je n'arrive pas à trouver les dimension de ce sac, ainsi que celles des tiroirs!
Est ce que une bonne âme aurait ça?? |
Toms24200 Ligue
Inscrit le: 26/03/2010 Messages: 231 Localisation: Sarlat (Dordogne)
Posté le: 22.04.2010, 21:51:51 Sujet du message: |
T'as oublié la photo  _________________ Thomas Couderc |
Posté le: 22.04.2010, 22:02:27 Sujet du message: |
Le grand avec 3 tiroirs
jbd100 Expert**
Posté le: 22.04.2010, 22:23:18 Sujet du message: |
In English ....
Description
Kyosho's best kept accessory secrets are not just for racers any more, new Kyosho pit bags are here and available to the masses! New pit bags are available in both a Medium for 1/10th scale size cars like the V One RRR, FW06, TF-5, EP Fazer, GP Fazer and DRX. The Large pit bag is made for larger scale vehicles like the 1/8th Evolva Evo M3 and off road buggies like the Inferno VE, Inferno MP9, DBX VE, DST or DRT. Each bag has 3 separate compartments, each compartment slides into its own heavy duty sleeve. The sleeve is riveted for extra strength. The compartments and sleeves are made from an industrial strength plastic that will hold up to any abuse you can dish out! No. 87615 Kyosho Pit Bag Large Pig Bag W: 14.1 x L: 22 x H: 21.6(Inches) Compartments W: 13.7 x L: 21.6 x H: 6.8(Inches)
http://www.shopkyosho.com/products/productdetail/KYOSHO+Carrying+Bag+Large+1/8/part_number=87615/410.0.1.1.25387.9420.0.0.0?
JP |
Posté le: 22.04.2010, 22:32:54 Sujet du message: |
Thank you JP
Vais convertir les inche en cm  |
Greg13wrt Ligue
Posté le: 23.04.2010, 08:37:16 Sujet du message: |
Salut Seb
les dimensions du sac Kyosho
longueur 55cm
largeur 35cm
hauteur 45cm |
Etan Champion du monde
Posté le: 23.04.2010, 09:04:20 Sujet du message: |
| et le prix de ce sac? |
crazydriver Elite
Posté le: 23.04.2010, 09:06:34 Sujet du message: |
dans les 70 - 80 euros
le gros avantage est qu'un TT 1/8 eme rentre dedans
les tirroirs sont en plastiques et non carton
inconvenient pas de roulettes  _________________
Posté le: 23.04.2010, 09:08:43 Sujet du message: |
!Houlà : pas bon pour mon dos ça!!!!  |
Posté le: 23.04.2010, 09:29:16 Sujet du message: |
| Etan a écrit: | !Houlà : pas bon pour mon dos ça!!!!  |
Comme quoi il faut même penser au sac quand on change de voiture  _________________ Gentil papy boomer un peu anar complétement déjanté
Posté le: 23.04.2010, 10:07:05 Sujet du message: |
non mais je reconnais il est pas mal surtout au niveau des tiroirs en plastoc.
cela dit sans roulette c'est un "nik dos" ce struc je connais bien j'en ai eu un Mugen (le premier violet) : on a tendance à en mettre beaucoup dedans et bien souvent de trop, du coup ben il se déchire et ca tient plus correctement!
heu j'y vais j'ai une machine à étendre.... !!!!  |
Posté le: 23.04.2010, 11:15:07 Sujet du message: |
| Greg13wrt a écrit: | Salut Seb
longueur 55cm
largeur 35cm
hauteur 45cm |
Merci Greg, je mesure chez moi et te tien au jus |
Golgot Elite
Inscrit le: 04/11/2004 Messages: 2928 Localisation: St Quentin (Picardie)
Posté le: 23.04.2010, 15:05:49 Sujet du message: |
| Etan a écrit: |
cela dit sans roulette c'est un "nik dos" ce truc
la solution pour Etan , qui commence à se faire vieux :
 _________________ Combien la TÝ? ah qd même...
Tant pis , fermes le encore ! |
Posté le: 23.04.2010, 22:22:07 Sujet du message: |
Bon ben nickel, ça me change de mes tiroirs en cartons ^^
Greg c'est bon j'ai pas trop bataillé avec les poignées  |
Etanpaparazzi Expert**
Inscrit le: 08/08/2007 Messages: 758 Localisation: Villers-lès-Nancy
Posté le: 24.04.2010, 01:49:42 Sujet du message: |
De rien Étienne !
 _________________ Losi Eight 2.0 EU, Brushless Embrayage et freins méca.
Losi Eight 2.0, B9, 3PK 2.4Ghz, Servos BLS.
Mag sponsor : Model Plus |
