bego Découverte
philippe27 Champion du monde
Posté le: 11.04.2009, 08:07:30 Sujet du message: |
effectivement prévu pour juin 2009
les modifs tournent autour des supports d'amortisseur en alu , des amortisseurs , boite radio/accus , de l'étrier du sauve servo en alu et surtout des cales ( pièces épaisse en alu) et a voir du cote de la direction...
voir ce lien
http://aedownloads.com/press/in_041009_ftrc8b.pdf
1:8 Scale Nitro 4WD Off-road Buggy Kit
The Factory Team RC8B picks up where the RC8 left off by adding many performance and durability enhancing features that were pioneered by our Area 51 engineers and world class pro team drivers, making a great buggy even better! The new RC8B features include Factory Team 16mm Big Bore threaded, hard-anodized shocks, updated 5mm 7075 blue aluminum shock towers, 7075 blue aluminum suspension mounts, Factory Team 7075 blue aluminum one-piece top plate, forward placement battery box, and optimized steering geometry. The RC8B gets you on the track fast, coming with pre-assembled shocks, diffs and turnbuckles, and also includes Factory Team shock and diff fluids. All of these refinements are what make the Factory Team RC8B, a potent buggy ready to take your racing to the next level, that is pure Associated!
The Factory Team RC8B Kit Features:
* Pre-assembled shocks, diffs, and turnbuckles with Factory Team shock and diff fluids included
* Factory Team 16mm Big Bore threaded, hard-anodized shocks feature heavy-duty 4mm TiN coated stainless steel shock shafts for maximum smoothness
* New 5mm 7075 blue aluminum shock towers allow the driver to stand the shock angle up for a more aggressive suspension
* Optimized front upper camber link bushings allow for more tuning options and are easier to adjust and maintain
* 7075 blue aluminum suspension mounts front and rear, with inserts to allow easy and quick adjustment of rear toe-in, rear anti-squat, and front kick-up
* Optimized steering geometry for more consistency and reduced bump-steer
* Updated wing mount with additional clearance for 16mm shocks
* Molded composite radio tray includes optional forward placement battery box for increased steering
* Molded composite front and rear chassis braces
* Tough steel-alloy shock stand-offs
* Factory Team 83mm big wheels included
* Machined aluminum racing clutch shoes
* Lightweight engine mounts
* Factory Team 7075 blue aluminum one-piece top plate
* Light-weight 3mm hard-anodized chassis
* 4.30:1 ratio gearboxes for maximum punch
* Heatsink brake discs with "FFC" Free Float Caliper brake system eliminates the possibility of unwanted brake drag while on throttle
* Two-piece split-center diff mount allows quick and easy access to the center diff
* Caster blocks adjust 14, 16, or 18 degrees with molded inserts
* 3.5mm light CVA drivetrain with full ball bearings
* Rear molded CVA boots to keep dirt and mud out of rear joints
* Blue aluminum hexes and nylon locking wheel nuts
RC8B Specifications
Scale: 1:8
Power: Nitro
Length: 470mm
Width: 305mm
Track: 259mm
Weight: 3570g*
Wheelbase: 323mm
Internal Gear Ratio: 4.30:1
Drive: 4WD
*Actual weight will vary depending on the engine, exhaust, electronics and tires used in the finished kit.
edit papymini: j'ai mis des photo de plus grande taille et de meilleur qualité OK
Posté le: 11.04.2009, 08:25:33 Sujet du message: |
et en plus le Team Asso a choisi un nouveau bleu pour un look sexy !!!! c'est asso qui le dit
Darkmo2 Elite
Inscrit le: 03/02/2007 Messages: 1843 Localisation: ligue 1
Posté le: 11.04.2009, 08:58:32 Sujet du message: |
| Sympa ça donne envie... |
Grizzly Découverte
Posté le: 11.04.2009, 09:59:31 Sujet du message: |
| Est ce que Associated va sortir un kit Upgrade permetant de faire évoluer l'actuelle RC8 en RC8 B ? |
Posté le: 11.04.2009, 10:20:38 Sujet du message: |
=> Press Release RC8B
J'ai édité le sujet pour le passer en HotNews  _________________ Gentil papy boomer un peu anar complétement déjanté
OGM Ligue
Posté le: 11.04.2009, 11:54:00 Sujet du message: |
bonne idée cette evolution,très réussi  |
quiks56 Elite
Inscrit le: 06/05/2007 Messages: 1369 Localisation: erdeven 56
Posté le: 11.04.2009, 19:16:51 Sujet du message: |
| plus qu'as attendre le mois de juillet maintenant |
smagrad Expert*
Posté le: 11.04.2009, 19:58:51 Sujet du message: |
| ca va etre long jusqu'au mois de juillet!!!!!!!!!!!!!! |
francky Ligue
Posté le: 11.04.2009, 20:01:34 Sujet du message: rc8b |
salut j espere qui feront un kit de convertion!!! sinon les support me plaisse!!!  |
quiks56 Elite
Posté le: 11.04.2009, 21:12:27 Sujet du message: |
| par contre il est plus lourd |
flo13 Elite
Posté le: 11.04.2009, 21:16:48 Sujet du message: |
| Darkmo2 a écrit: | | Sympa ça donne envie... |
+1, vraiment une bonne idée. |
molto88 Elite
Posté le: 12.04.2009, 09:23:25 Sujet du message: |
pensez vous que la platine radio va aller sur le rc8 actuel? _________________ S88R/ZENOAH/PMT
MP9/OS SPEED/PROLINE
http://www.vosloisirs88.com/modelisme/
TEAM FORAIN
rien ne sert de courir...non ca sert a rien!!! |
OGM Ligue
Posté le: 12.04.2009, 09:37:16 Sujet du message: |
bingmans Ligue
Posté le: 12.04.2009, 09:50:49 Sujet du message: |
pour la platine radio c'est tout simplement la platine plastique du rtr...
donc en principe ca devrait aller
en fait c'est ni plus ni moins que la version commerciale des rc8 de
mayfield et cavalieri .....avec toutes les modifs faites depuis plus d'un an
accu devant ,barre ackerman courte , big bor ,platine radio et renfort du
rtr ....
les seules vraies nouvautees sont les cales alu asso et les supports
amortisseurs .... |
quiks56 Elite
Posté le: 12.04.2009, 10:27:06 Sujet du message: |
| t'as oublier la possibilité de changer l'angle des fusée avant14 16 ou 18°, j'ai remarqué qu'il n'y avait plus de bague bleu sur la fusée pour la fixation du tirant supérieur |
Posté le: 12.04.2009, 10:32:55 Sujet du message: |
Il faut se méfier avec Associated, au premier abord, les pièces sont interchangeables d'un modèle à l'autre, et en fait  _________________ Gentil papy boomer un peu anar complétement déjanté
bingmans Ligue
Posté le: 12.04.2009, 10:49:23 Sujet du message: |
| quiks56 a écrit: | | t'as oublier la possibilité de changer l'angle des fusée avant14 16 ou 18°, j'ai remarqué qu'il n'y avait plus de bague bleu sur la fusée pour la fixation du tirant supérieur |
les rondelles bleues pas faciles à mettre en place on l'air d'etre
remplacées par des rondelles coniques en alu... |
Posté le: 12.04.2009, 11:06:19 Sujet du message: |
certaines pièces sont déjà sur le RC8 de Robert Batlle ???
quiks56 Elite
Posté le: 13.04.2009, 10:33:51 Sujet du message: |
| vue que les nouvelles cales sont percées sont elles prevuent pour des axes filetés? |
Etan Champion du monde
Posté le: 13.04.2009, 12:17:33 Sujet du message: |
Je pense pas, le trou permet de virer l'insert plastoc facilement!! Mais bon faut voir, Asso ne m'a rien dit...!!  |
bibi49 Champion du monde
Posté le: 16.04.2009, 13:42:40 Sujet du message: |
bonne idée cette évolution !!!! dommage par contre pour le poids, elle commence a être lourde vis à vis de la concurrence... _________________ "S'il n'y a pas de solution...c'est qu'il n'y a pas de problème..." |
PP Champion du monde
Posté le: 16.04.2009, 16:32:33 Sujet du message: |
| Changement de fixation d'amortisseurs aussi... retenu par BTR. |
quiks56 Elite
Posté le: 16.04.2009, 20:22:33 Sujet du message: |
| la fixation basse d'amorto existe depuis que le rc8t existe donc ça fait un moment que c'est dispo |
kamigaze Expert**
Inscrit le: 24/07/2008 Messages: 746 Localisation: ligue 10 Pegase RC APT
Posté le: 22.04.2009, 20:26:43 Sujet du message: |
et merde..........
ca sent l'achat compulsif a plein nez cette histoire........ _________________ El Magico |
Posté le: 23.04.2009, 14:35:53 Sujet du message: |
Dommage qu'ils n'intègrent pas mieux le pack d'accu à la platine: certe la pack devant c'st mieux pour la répartition des masses, mais ils auraient pu faire une belle platine style D8 ou EIGHT. et du coup changer la grosse boite radio qui ne sert plus à rien par un modèle plus petit...
Bref, du bricolage pour l'hiver !!!! _________________ "S'il n'y a pas de solution...c'est qu'il n'y a pas de problème..." |
OGM Ligue
Posté le: 27.04.2009, 09:37:32 Sujet du message: |
pour le tarif 849$ environ 653 euro apparement.  _________________ asso rc8b4.1,os,procircuit,sanwa,savöx,nitrolux. |
quiks56 Elite
Posté le: 27.04.2009, 10:59:45 Sujet du message: |
| je sais pas ou tu as trouvé ce prix là mais ça à mon avis c'est le prix avec les taxes americaine tu peux le trouver en prevente à 519.99 dollars soit environ 400 euros |
33julien33 Découverte
Posté le: 19.05.2009, 21:13:53 Sujet du message: |
Le manuel du RC8B est déja en ligne, bizarre.
On y retrouve donc toutes les modifs annoncées, plus quelques petits changements.
J'ai l'impression qu'il y a du changement au niveau des cardans centraux, il n'y a plus de vis de maintien de l'axe dans la noix, non? :
http://aedownloads.com/downloads/manuals/rc8b_manual.pdf |
Posté le: 19.05.2009, 21:20:50 Sujet du message: |
| non il n'y a plus, sur le RC8E il n'y en a pas. Après ca coute rien dans mettre une... on sait jamais... |
