RCmag :: Voir le sujet - RC8B Team Associated + options.
RC8B Team Associated + options. Aller à la page 1, 2, 3  Suivante
bego
MessagePosté le: 11.04.2009, 02:32:10    Sujet du message: RC8B Team Associated + options. Répondre en citant
http://67.199.85.166/main/productdetails.php?text=80902&category=facto
de nouvelle options pour le RC8B a voir !!!!
philippe27
MessagePosté le: 11.04.2009, 08:07:30    Sujet du message: Répondre en citant
effectivement prévu pour juin 2009
les modifs tournent autour des supports d'amortisseur en alu , des amortisseurs , boite radio/accus , de l'étrier du sauve servo en alu et surtout des cales ( pièces épaisse en alu) et a voir du cote de la direction...
voir ce lien
http://aedownloads.com/press/in_041009_ftrc8b.pdf
1:8 Scale Nitro 4WD Off-road Buggy Kit
The Factory Team RC8B picks up where the RC8 left off by adding many performance and durability enhancing features that were pioneered by our Area 51 engineers and world class pro team drivers, making a great buggy even better! The new RC8B features include Factory Team 16mm Big Bore threaded, hard-anodized shocks, updated 5mm 7075 blue aluminum shock towers, 7075 blue aluminum suspension mounts, Factory Team 7075 blue aluminum one-piece top plate, forward placement battery box, and optimized steering geometry. The RC8B gets you on the track fast, coming with pre-assembled shocks, diffs and turnbuckles, and also includes Factory Team shock and diff fluids. All of these refinements are what make the Factory Team RC8B, a potent buggy ready to take your racing to the next level, that is pure Associated!
The Factory Team RC8B Kit Features:
* Pre-assembled shocks, diffs, and turnbuckles with Factory Team shock and diff fluids included
* Factory Team 16mm Big Bore threaded, hard-anodized shocks feature heavy-duty 4mm TiN coated stainless steel shock shafts for maximum smoothness
* New 5mm 7075 blue aluminum shock towers allow the driver to stand the shock angle up for a more aggressive suspension
* Optimized front upper camber link bushings allow for more tuning options and are easier to adjust and maintain
* 7075 blue aluminum suspension mounts front and rear, with inserts to allow easy and quick adjustment of rear toe-in, rear anti-squat, and front kick-up
* Optimized steering geometry for more consistency and reduced bump-steer
* Updated wing mount with additional clearance for 16mm shocks
* Molded composite radio tray includes optional forward placement battery box for increased steering
* Molded composite front and rear chassis braces
* Tough steel-alloy shock stand-offs
* Factory Team 83mm big wheels included
* Machined aluminum racing clutch shoes
* Lightweight engine mounts
* Factory Team 7075 blue aluminum one-piece top plate
* Light-weight 3mm hard-anodized chassis
* 4.30:1 ratio gearboxes for maximum punch
* Heatsink brake discs with "FFC" Free Float Caliper brake system eliminates the possibility of unwanted brake drag while on throttle
* Two-piece split-center diff mount allows quick and easy access to the center diff
* Caster blocks adjust 14, 16, or 18 degrees with molded inserts
* 3.5mm light CVA drivetrain with full ball bearings
* Rear molded CVA boots to keep dirt and mud out of rear joints
* Blue aluminum hexes and nylon locking wheel nuts
RC8B Specifications
Scale: 1:8
Power: Nitro
Length: 470mm
Width: 305mm
Track: 259mm
Weight: 3570g*
Wheelbase: 323mm
Internal Gear Ratio: 4.30:1
Drive: 4WD
*Actual weight will vary depending on the engine, exhaust, electronics and tires used in the finished kit.
edit papymini: j'ai mis des photo de plus grande taille et de meilleur qualité Wink OK
philippe27
MessagePosté le: 11.04.2009, 08:25:33    Sujet du message: Répondre en citant
et en plus le Team Asso a choisi un nouveau bleu pour un look sexy !!!! c'est asso qui le dit
Darkmo2
MessagePosté le: 11.04.2009, 08:58:32    Sujet du message: Répondre en citant
Sympa ça donne envie...
Grizzly
MessagePosté le: 11.04.2009, 09:59:31    Sujet du message: Répondre en citant
Est ce que Associated va sortir un kit Upgrade permetant de faire évoluer l'actuelle RC8 en RC8 B ?
MessagePosté le: 11.04.2009, 10:20:38    Sujet du message: Répondre en citant
=> Press Release RC8B
J'ai édité le sujet pour le passer en HotNews Wink
OGM
MessagePosté le: 11.04.2009, 11:54:00    Sujet du message: Répondre en citant
bonne idée cette evolution,très réussi OK!
quiks56
MessagePosté le: 11.04.2009, 19:16:51    Sujet du message: Répondre en citant
plus qu'as attendre le mois de juillet maintenant
smagrad
MessagePosté le: 11.04.2009, 19:58:51    Sujet du message: Répondre en citant
ca va etre long jusqu'au mois de juillet!!!!!!!!!!!!!!
francky
MessagePosté le: 11.04.2009, 20:01:34    Sujet du message: rc8b Répondre en citant
salut j espere qui feront un kit de convertion!!! sinon les support me plaisse!!! OK!
quiks56
MessagePosté le: 11.04.2009, 21:12:27    Sujet du message: Répondre en citant
par contre il est plus lourd
flo13
MessagePosté le: 11.04.2009, 21:16:48    Sujet du message: Répondre en citant
+1, vraiment une bonne idée.
molto88
MessagePosté le: 12.04.2009, 09:23:25    Sujet du message: Répondre en citant
pensez vous que la platine radio va aller sur le rc8 actuel?
S88R/ZENOAH/PMT
MP9/OS SPEED/PROLINE
http://www.vosloisirs88.com/modelisme/
TEAM FORAIN
rien ne sert de courir...non ca sert a rien!!!
OGM
MessagePosté le: 12.04.2009, 09:37:16    Sujet du message: Répondre en citant
Question
bingmans
MessagePosté le: 12.04.2009, 09:50:49    Sujet du message: Répondre en citant
pour la platine radio c'est tout simplement la platine plastique du rtr...
donc en principe ca devrait aller Laughing
en fait c'est ni plus ni moins que la version commerciale des rc8 de
mayfield et cavalieri .....avec toutes les modifs faites depuis plus d'un an
accu devant ,barre ackerman courte , big bor ,platine radio et renfort du
rtr ....
les seules vraies nouvautees sont les cales alu asso et les supports
amortisseurs ....
quiks56
MessagePosté le: 12.04.2009, 10:27:06    Sujet du message: Répondre en citant
t'as oublier la possibilité de changer l'angle des fusée avant14 16 ou 18°, j'ai remarqué qu'il n'y avait plus de bague bleu sur la fusée pour la fixation du tirant supérieur
MessagePosté le: 12.04.2009, 10:32:55    Sujet du message: Répondre en citant
Il faut se méfier avec Associated, au premier abord, les pièces sont interchangeables d'un modèle à l'autre, et en fait Evil or Very Mad
bingmans
MessagePosté le: 12.04.2009, 10:49:23    Sujet du message: Répondre en citant
les rondelles bleues pas faciles à mettre en place on l'air d'etre
remplacées par des rondelles coniques en alu...
philippe27
MessagePosté le: 12.04.2009, 11:06:19    Sujet du message: Répondre en citant
certaines pièces sont déjà sur le RC8 de Robert Batlle ???
quiks56
MessagePosté le: 13.04.2009, 10:33:51    Sujet du message: Répondre en citant
vue que les nouvelles cales sont percées sont elles prevuent pour des axes filetés?
Etan
MessagePosté le: 13.04.2009, 12:17:33    Sujet du message: Répondre en citant
Je pense pas, le trou permet de virer l'insert plastoc facilement!! Mais bon faut voir, Asso ne m'a rien dit...!! Arrow
bibi49
MessagePosté le: 16.04.2009, 13:42:40    Sujet du message: Répondre en citant
bonne idée cette évolution !!!! dommage par contre pour le poids, elle commence a être lourde vis à vis de la concurrence...
PP
MessagePosté le: 16.04.2009, 16:32:33    Sujet du message: Répondre en citant
Changement de fixation d'amortisseurs aussi... retenu par BTR.
quiks56
MessagePosté le: 16.04.2009, 20:22:33    Sujet du message: Répondre en citant
la fixation basse d'amorto existe depuis que le rc8t existe donc ça fait un moment que c'est dispo
kamigaze
MessagePosté le: 22.04.2009, 20:26:43    Sujet du message: Répondre en citant
et merde..........
ca sent l'achat compulsif a plein nez cette histoire........
El Magico
bibi49
MessagePosté le: 23.04.2009, 14:35:53    Sujet du message: Répondre en citant
Dommage qu'ils n'intègrent pas mieux le pack d'accu à la platine: certe la pack devant c'st mieux pour la répartition des masses, mais ils auraient pu faire une belle platine style D8 ou EIGHT. et du coup changer la grosse boite radio qui ne sert plus à rien par un modèle plus petit...
Bref, du bricolage pour l'hiver !!!!
OGM
MessagePosté le: 27.04.2009, 09:37:32    Sujet du message: Répondre en citant
pour le tarif 849$ environ 653 euro apparement. Confused
asso rc8b4,sirio xl5,procircuit,sanwa,savox,runnertime.
quiks56
MessagePosté le: 27.04.2009, 10:59:45    Sujet du message: Répondre en citant
je sais pas ou tu as trouvé ce prix là mais ça à mon avis c'est le prix avec les taxes americaine tu peux le trouver en prevente à 519.99 dollars soit environ 400 euros
33julien33
MessagePosté le: 19.05.2009, 21:13:53    Sujet du message: Répondre en citant
Le manuel du RC8B est déja en ligne, bizarre.
On y retrouve donc toutes les modifs annoncées, plus quelques petits changements.
J'ai l'impression qu'il y a du changement au niveau des cardans centraux, il n'y a plus de vis de maintien de l'axe dans la noix, non? Confused:
http://aedownloads.com/downloads/manuals/rc8b_manual.pdf
PP
MessagePosté le: 19.05.2009, 21:20:50    Sujet du message: Répondre en citant
non il n'y a plus, sur le RC8E il n'y en a pas. Après ca coute rien dans mettre une... on sait jamais...
Page 1 sur 3
