RCmag :: Voir le sujet - PROSTAR R/C MAG-BRAKE - frein électromagnétique TT 1/8, 1/5
francky340
MessagePosté le: 31.03.2022, 07:44:24    Sujet du message: PROSTAR R/C MAG-BRAKE - frein électromagnétique TT 1/8, 1/5 Répondre en citant
francky340
MessagePosté le: 31.03.2022, 07:46:03    Sujet du message: Répondre en citant
francky340
MessagePosté le: 31.03.2022, 07:47:57    Sujet du message: Répondre en citant
francky340
MessagePosté le: 31.03.2022, 07:49:12    Sujet du message: Répondre en citant
francky340
MessagePosté le: 31.03.2022, 07:50:17    Sujet du message: Répondre en citant
The Newest Innovation in RC Car History
We are pleased to introduce the only patented Electro-Magnetic Braking system for 1/8, 1/5 scale nitro vehicles. Our innovation takes all the noise and fuss out of braking for your nitro vehicle as you enjoy backyard bashing or simply winning races and chasing titles.
The Mag Brake by Prostar RC Products is the world’s only universal mag brake kit for RC Cars, simple to use, and brings the Fun back into Nitro RC Cars. We developed this with you in mind.
The Mag Brake makes it simple using only 8 parts. Eliminating up to 47 parts from the conventional brake system in a Nitro Car including multiple Linkage, Cams, Springs, screws, stops, spacers, bearings, Rods, Pads, and the large throttle brake servo.
INSTALLATION IS EASY
Simply remove your center bulkhead and differential. Re-using the stock differential and top plate, install our Universal Mag Brake and Car model-specific Adapter kit in minutes. Power is supplied using the standard 7.4vdc receiver pack with a Dean’s plug for quality on and off connection. Connect the Mag brake controller to your throttle servo, front, and rear magnets, and to the receiver. No additional channels are necessary.
SETUP IS SIMPLE
Download the Free Android or IOS application, power up your car. Pair. and Adjust using our Powerful Class 1 Bluetooth, capable of up to 300feet depending on your model of phone
You can adjust the following using the app
Bias (Front and Rear)
Drag Brake (Front and Rear)
Drag Brake Duration
Brake Curve
Static Brake Strength (to conserve power)
Demagnetization (if required)
Engine Temperature Monitoring with Alarm
Receiver battery Voltage with Alarm
Transfer Setups to Friends between Android and Ios Users
Quick Access to different models for example back-to-back races using the same app.
Save up to 10 models
Send us your suggestions or comments
And feel free to hit the share button in the upper right.
Universal Mag-Brake Kit Includes – 1/8 Scale
- Mag-Brake Control board - (Production Controller will have waterproof enclosure)
- (2) Electromagnets
- (4) Friction Plates
- (1) Micro Servo adapter plate
- (1) Micro Servo Horn
- (1) Temperature sensor
Choose your Adapter kit:
To get the correct bulkhead and brake disc and any other parts necessary please select your model car below. If your car is not listed please email us at prostarrcproducts@gmail.com
Choose Your Car Model:
Brand, Model, Style, Year
Download your application, Apple Store for Ios Google Play for Android (available when on sale)
Model Applications, Media or License inquires may be requested by Email
Expected Release Dates for Models, Based on Demand
- July 2022: RC8B4, TLR8ightX, MBX8R, Others to follow
- December 2022 1/5 Scale TLR 5ive and others to follow
francky340
MessagePosté le: 31.03.2022, 07:51:32    Sujet du message: Répondre en citant
le lien vers le site PROSTAR R/C
https://prostarrc.ecwid.com/MAG-BRAKE-Electro-Magnetic-Braking-Universal-Kit-by-ProStar-RC-p452874451
MessagePosté le: 31.03.2022, 08:17:10    Sujet du message: Répondre en citant
L'idée est top mais ...
(j'aime bien les mais)
Dommage que ça ne fasse que consommer ; pourrait y avoir de la régénération pour prolonger l'autonomie du pack Mr. Green
Mickaelkael
MessagePosté le: 31.03.2022, 08:57:01    Sujet du message: Répondre en citant
Si c’est pas trop lourd … cela irait bien à l’avant du 4x2 … directement sur les axes de roues …
Michael M. (Ligue 2) PMC (416) AMMA (1119)
4x4 TH: Agama A319, OS B2103
4x2 TH: Hyper 808 , OS VZB
4x2 BL: JCA Sword, WS Line
MessagePosté le: 02.04.2022, 00:32:13    Sujet du message: Répondre en citant
poisson d'avril ou pas ? Laughing
MessagePosté le: 02.04.2022, 06:40:00    Sujet du message: Répondre en citant
Là c'est poussé quand même.
En mettant ça uniquement sur l'avant et sur une autre voie que celle des gazs, y'a moyen de faire des gros burn Laughing
Essai proto mais on voit pas grand chose ...
