New 1/8 remote control tricycle flamingo is coming soon from our company.
Design inspiration of this tricycle comes from Piaggio Ape in Italy. This tricycle is very maneuverable and equipped with powerful motorcycle engine and delta tricycle design.
Widen the wheelbase of the original narrow rear wheel to decrease the problem of rolling over. The cornering performance is smooth and the posture is as like drift car, which is also suitable for two wheel tilt stunts. It also faithfully derives its appearance and features from the real tricycle. The changing shape and the head-shaking cartoon of driver make the whole tricycle more entertaining.
This tricycle is easy to drive and install and it can be added with a wealth of extensive accessories and appearance. And it is quite suitable for DIY interaction between parents and children, through such a common topic, through such a common topic, increase the friendship between Parent-child.
This tricycle has been successfully applied for exterior design patent on the Chinese mainland and the European Union.
2 in1 ESC/RX
32T Brushed Motor
800mAh NiMH
Digital Servo
Charger
high simulated ABS car body
Adorable head-shaking driver
Thickened 6061 Aluminum chassis
Reinforced metal guard assy
High toughness fiber roll cage
High simulated water cooling radiator
High simulated engine
High performance spoiler
Multi-link suspension
Retro truck rim
All terrain tire
Upgrade to brushless power system
Plastic parts upgrade to Metal
(Shock Absorber Triples、Steering Support、Front /Rear Shock Absorber、
Front Brake、Front/Rear Rim)
PC cylinder
PC truck body
Increase lamplight
Increase audio
La description:
Informations de base Marque:X-Rider
Numéro d'article:Flamant
Échelle: 1/8
Couleur: rouge, jaune et vert
Vitesse maximale: 40 km / h Système du pouvoir ESC: 2 en 1 esc
Moteur: Moteur balayé 370 32T
Servo:Servo numérique
Émetteur Fréquence: 2.4G Batterie Batterie de voiture: batterie 7.2v 800mAh Ni-mh (incluse)
Autre Matériel: ABS et composants électroniques Dimension Taille de la voiture:258x192x175mm
Caractéristiques:
Pare-chocs en métal et amortisseurs
Plaque inférieure en alliage d'aluminium 6061
Facile à conduire et à installer
La performance en virage est lisse et la posture est comme une voiture à la dérive
Convient aux cascades à deux roues
Les changements de forme et le dessin animé du pilote rendent le tricycle plus divertissant
Convient pour les interactions de bricolage entre parents et enfants, à travers un sujet aussi commun, à travers un sujet si commun, renforce l’amitié entre parents et enfants
Emballage inclus:
1X Rc Car (inclus la batterie de voiture)
Émetteur 1X
1X câble de charge USB
Manuel 1X
