RCmag :: Voir le sujet - Axes de différentiel alliage haute température XRAY.
MessagePosté le: 26.03.2019, 13:31:03    Sujet du message: Axes de différentiel alliage haute température XRAY. Répondre en citant
Extreme Heat Resistant Diff Pins with Inserts
• 30% lighter
• For extreme heat conditions
• Smoother run
• Precision ground
• Steel inserts
• For large front & rear & center diffs
• Increases lifetime
#355086 Extreme Heat Resistant F/R Alu Diff Pin with Inserts (2+4)
Precision-ground polished alu pin 3.5 x 26.6 mm for internal satellite gears used in large front & rear differentials #355004 and #355005. Mounted in steel inserts instead of directly mounted in differential case increases the lifetime, especially in high temperatures. 30% lighter than steel pins. Set of 2.
#355087 Extreme Heat Resistant Center Alu Diff Pin with Inserts (2+4)
Precision-ground polished alu pin 3.5 x 33 mm for internal satellite gears used in large center differential #355013. Mounted in steel inserts instead of directly mounted in differential case increases the lifetime, especially in high temperatures. 30% lighter than steel pins. Set of 2.
Source TeamXRAY
