Intuitive Touch Screen Display
HV (High Voltage) charging / discharging / balancing
Charges Li-Po/Li-Fe/ (1-6 cell), Ni-MH (1-15 cell) and Pb battery types
500W internal power supply
0.1-10.0A Adjustable charge current per output
Space saving dual output design
200W charge power per output
100-240 VAC (50/60Hz) or 11-18V DC input voltage
25W discharge power per output
Detachable AC power cord / Optional DC power cord
Includes 2 EC3 charge connector and a variety of other connectors included
Short circuit protection
Over temperature protection / Over current protection
Low input voltage protection
Overview
The Dynamite® Passport™ Duo 400W Dual AC/DC Touch Charger builds on the success of the the previous non-touch version and adds an intuitive easy to use touch screen interface and HV charging capabilities.
AC Input: 100-240V AC
Ampere Meter: Yes – on main LCD display
Battery Balance Connector: JST_XH
Battery Temperature Monitoring: Yes - Temperature Sensor (not) included
Battery Type: LiFe, LiIon, LiPo, NiCd, NiMH, Pb
Circuit Breaker: No
Cooling Method: Fan
DC Input: 11-18V DC
Discharge: Yes
Display: Monochrome Touch Screen, 400x240
Fuse: No
Height: 0 in (0mm)
Input Connector: AC cord, detachable, North American plug
Insulation Type: Earth ground
Integrated Balancing: Yes - Internal Balancer & External Adapter
Length: 0 in (0mm)
Low Input Voltage Protection: Yes
Maximum Continuous Discharge Rate: .01 - 5.0A/25W per channel
Model Memory: Yes - 20 Battery Settings
Output Connector: Banana to EC3, Banana to Deans Compatible, Banana to Rx
Over Current Protection: Yes
PC Connectivity: Yes – USB, external adapter required
PC Required: No
Peak Detection: Yes
Reverse Polarity Protection: Yes
Safety Timer: Yes
Selectable Charge Rate: Yes - Incremental (0.1A Increments)
Short Circuit Protection: Yes
Software Updates: Yes - via USB port
Thermal Protection: Yes
Voltage Meter: Yes – on main LCD display
Weight: 0 lbs (0kg)
Width: 0 in (0mm)
