Posté le: 21.08.2016, 09:37:16 Sujet du message: Chargeur Venom Pro Quad C
Building on the success of our Pro Duo charger, the Venom Pro Quad 4-port, 7.0A Multi-Chemistry balance charger is the ultimate solution for hobbyists looking to charge multiple packs quickly and conveniently.
Featuring a monolithic vertical stance, this charger saves valuable bench space by providing four complete charging circuits, each with its own dedicated 100W integrated power supply in a footprint similar to most single output chargers.
Having four dedicated power supplies in one compact package means all four channels are able to receive 100W of power, ensuring you are not diluting your amp rate when charging two, three, or four packs simultaneously. Discreetly located on the back of the charger are two powerful USB 2.3 Amp charging ports to conveniently power your USB devices.
Menu navigation is made easy with a five-button control interface and brightly backlit LCD screen. All the most common battery chemistries are supported including: LiPo, LiHV, LiFe, Li-Ion, NiMH, NiCD, and Pb (lead acid) with a complete assortment of charge leads included in the box along with extra long balance leads to make safe charging in a LiPo sack effortless.
Specs:
Included Charge Leads: Alligator, Deans, EC3, EC5, HXT 4, JST, Receiver (RX), Tamiya, XT60
LiPo/LiHV/LiFe/Li-Ion Cell Count: 1-6 Cell
NiCd/NiMH Cell Count: 1-15 Cell
Pb Battery Voltage: 2-20V
Charge Current: 4 x 0.1 – 7.0A
Discharge Rate: 0.1 – 1.0A
Circuit Power: 4 x 100W
Current Drain Balancing: 300mAh per Cell
USB Output: 2 x 5V 2.3A USB 2.0
Input: DC 11.0V-18.0V – AC 100V-240V
Display Type: LCD
Length: 7 in (178mm)
Height: 9.25 in (235mm)
Width/Diameter: 4.25 in (108 mm)
#0686 – $229.99
Visit VenomPower.com
See more posts about Venom
[/img]
Charge Current: 4 x 0.1 - 7.0A
Discharge Rate: 0.1 - 1.0A
Input: DC 11.0V-18.0V - AC 100V-240V
Display Type: LCD
