Posté le: 29.02.2016, 14:40:39 Sujet du message: Dimension GT3X AFHDS 2.4ghz 3 Channel radio system
new Dimension GT3X AFHDS 2.4ghz 3 Channel radio system. This sleek radio system features excellent ergonomics and design. The Transmitter uses proven channel hopping technology to provide reliable link for RC Cars & Boats. The Dimension GT3X features a Back-lit LCD, quick access wheel for function selection and programming. The radio has an abundance of features and settings such as 10 Model memory, a host of programming features and compatibility with the proven FS-A3 3 Channel receiver. The steering wheel has great response with the perfect amount of resistance and spring back to center perfectly. The foam grip around the wheel will ensure your fingers do not slip if they are covered in dirt or oil. The combination of features and reliability means the Dimension GT3X could be the last radio you will ever need to get!
Transmitter Specs:
Channels: 3
Channel resolution: 1024 steps
Power supply: 6v (1.5V AA x 4)
Low voltage warning:? <4.2v Red LED will flash
4.2 - 4.5v Red
4.6 ¡V 5v Orange
5 ¡V 6v Green
<3.2v Buzzer goes off to alarm
