Posté le: 19.01.2015, 23:38:03 Sujet du message: Picco Boost 5TX Team 21 engine
Picco is proud to announce the newest addition to the Boost .21 engine lineup! The new PICCO Boost 5TX Team .21 engine. This new engine was designed to provide the same incredible reliability, fuel mileage and ease of tuning of the popular 5TR but with increased bottom end for drivers who crave that aggressive and punchy bottom end power delivery! The PICCO Boost 5TX has a new 14mm balanced and silicone filled crankshaft to improve overall performance, a larger more efficient grey cooling head, new crankcase design allows more clearance for different flywheels, super strong “kife edged” connecting rod, lightened piston CNC machined from high percentage silicone alloy billet and a ceramic “Swiss” made rear bearing tops off the list of all the hgih end features
The Boost 5TX Team engine is a top of the line racing egnine with a strong and aggressive bottom end powerband and incredible top end performance. Perfect for high grip tracks or tracks with difficult jumps where off the line power is crucial. Combine all of this with its super stable tuning, incredible fuel mileage and PICCO’s legendary quality this makes it the total package in a Pro level buggy or truggy engine
3.49cc, bore 16.26, stroke 16.80, output 2.6hp @ 33k rpm,RPM 3000-41000 Part# PIC9540 • 5+2 port hard chromed liner • Piston CNC machined from billet • 14mm balanced crankshaft with silicone insert • Knife edged aerodynamic connecting rod • New larger cooling head design to maximize efficiency • Ceramic “Swiss” main bearing • New case design for better performance and clearance • Composite long needle carburetor • includes 6.0mm and 7.0mm venturi inserts
