Posté le: 07.12.2013, 17:50:16 Sujet du message: Sworkz S350 BK1 Evo Kit Detail Information !!!
SWORKz S350 BK1 EVO Kit Detail Information
The Evolution of the S350 project is the result of SWORKz passion for improvement. Combining every detail into a more balanced and improved buggy called the "S350 BK1". The SWORKz S350 BK1 Evolution Pro Kit comes standard with many SWORKz Factory Team Option Parts which improve strength, performance, and value.
SWORKz utilizes only the highest quality materials and industry leading manufacturing processes resulting in a faster, stronger, and more reliable vehicle. The S350 BK1 Evolution Pro Kit from SWORKz has been designed to out-perform the competition on any Off-Road terrain while offering amazing performance to drivers of all levels.
1. Comes standard with F.C.S.S. A race design lightened chassis with T6 7075 aluminum in B.H.C (black hard coating).
2. Standard with front and rear 2.0 Pro Shock Towers made of lightened 7075 aluminum.
3. New Hex-Cell Shock Bladder design with Special Impact Shock Piston system. Pro Shock 2.0 system with 4mm shock shafts.
4. High Performance Crown Gears and Pinion Gears.
5. Full CVD Drive Shafts.
6. New Rear Lower Plastic Insert Toe-In system.
7. Double Protection Bumper Design.
8. PSP (Power Steering Package) radio tray system.
9. Professional 2.0 Metal Brake Calipers
10. New fuel tank with Floating Fuel Filter system.
11. Adjustable front upper and lower suspension arm system.
12. Falcon Clear Body Shell included.
