RCmag :: Voir le sujet - Area RC Centre Diff Bracket Adjustable Caliper version for L
philippe27
MessagePosté le: 18.07.2014, 08:35:48    Sujet du message: Area RC Centre Diff Bracket Adjustable Caliper version for L Répondre en citant
Area RC introduce this centre diff bracket (or bulkhead if you will) with adjustable brake callipers. The set contains 6061-T6 aluminium bulkheads, an aluminium upper brace, aluminium callipers and copper brake pads. The design of the callipers allows to adjust the gap between the brake pads and the rotors via a 4mm hex driver as you may know it from mechanical brake discs of bicycles. The set is a direct replacement for the stock centre bulkhead assembly, it is available in red or silver anodising and includes all needed mounting hardware.
[url][/url]
http://arearc.com/products/newProducts/Area%20RC%20Centre%20Diff%20Bracket%20Adjustable%20Caliper%20version%20for%20LOSI%20DBXL/
http://arearc.com/
