Posté le: 01.02.2013, 10:43:19 Sujet du message: Moteur Seiki SR2172B is a 7+2 port competition Buggy
Soar Seiki SR2172B is a 7+2 port competition Buggy engine. The SR2172B 7+2 port sleeve and a 14mm long stroke cranckshaft significantly reduces fuel consumption without affecting the power output providing the perfect balance of power and run time. The low CG and light weight head contributes to improved car control and performance thanks to it 9 fin optimized cooling head.
Proven 9 port sleeve design provides optimum engine performance with smooth, crisp acceleration and fuel efficiently. Turbo slide crankshaft made from the highest grade steel using state of the art manufacturing for precision and balance. Cranckshaft is hardened for a maximum hardness for extended life without compromising toughness.
