* Operation voltage range : DC: 11.0~18.0 Volt
* Circuit power: Max : Charge power 2*200Watts
* Max :Discharge power 2*25
* Charge current range : (0.1~10A)
* Discharge current range : 2*(0.1~5A)
* Current drain for balancing Li-Po/Lon/Fe : 200Ma/cell
* Li-ion/Fe/Polymer cell count : (1~6cells)
* NiCd/NiMH battery cell count : 1~18cells
* Pb battery voltage : 2V~24V
* Net weight : 350g
* Dimension : 160*200*60mm
Imax RC 4B6 06 Pro Intelligent Balance Charger
XRC Charger Names
Item Number: 471032
IMAX RC 4B6 06 PRO INCLUDES
Input voltage: 11-18VDC
Charge power: 80Wx4
Power Source: 12V DC(car battery)/AC mains PSU(>200watts)
Cell count: 1-18 NiCd/NiMHx4/ 1-6 Li-ion/Polymer Cellx4/ 1-10 Lead acid cells(2~20V)x4
Current drain for balancing Li-ion/Polymer cell: 20mAh/cell
Charge termination NiCd/NiMH: Automatic, negative Delta Peak method
Charge termination Lead acid&Li-ion/Polymer: Automatic, negative dependent, CC-CV process
Dimension: 220mm X 150mm X 40mm
Weight: 1300g
http://www.imaxrc.com/4B606-Pro.html
max RC 4B6 Pro Intelligent Balance Charger
IMAX RC 4B6 PRO RC PECIFICATION
* Input voltage: 11-18VDC
* Charge power: 50Wx4, current is regulated accordingly
11.1Vbattery, charge current appro. 4.5A
22.2V battery, charge current approx.2.2A
* Discharge power: 5Wx4, current is regulated accordingly
* Power Source: 12V DC(car battery)/AC mains PSU(>200watts)
* Cell count: 1-15 NiCd/NiMHx4/1-6 Li-ion/Polymer
Cellx4/1-10 Lead acid cells(2~20V)x4
* Current drain for balancing Li-ion/Polymer vell: 300mAh/cell
* Charge termination NiCd/NiMH: Automatic,negative Delta Peak method
* Charge termination Lead acid&Li-ion/Polymer: Automatic,negative dependent, CC-CV process
* Dimension: 230mm X 150mm X 40mm
* Weight: 840g
*The Naming Motivation of IMAXRC Charger Names
IMAX RC 4B6 OMPARISON WITH OTHER CHARGERS:
Batt. Type Lipo LiFe Li-lon NiMH/NiCd Pb
Voltage 3.7V/cell 3.3V/cell 3.6V/cell 1.2V/cell 2.0V/cell
Max. 4.2V/cell 3.6V/cell 4.1V/cell 2.46V/cell
Current <=1C <=4C <=1C 1C~2C <=0.4C
Discharge 3.0V/cell 2.0V/cell 3.0V/cell 1.0V/cell|0.85V/cell 1.75V/cell
