RCmag :: Voir le sujet - Chargeur Dynamite Passport
philippe27
MessagePosté le: 20.01.2012, 09:35:32    Sujet du message: Chargeur Dynamite Passport Répondre en citant
Dynamite Passport Ultra Charger
http://www.youtube.com/watch?v=4ULdDmpxx2U&feature=related
FEATURES
* Integrated 1-6S Li-Po balancer
* 8 Amp charge rate provides quick charge times
* 5 Amp discharge rate
* AC/DC input provides flexible charging capabilities
* Blue backlit screen for easy viewing
* Charges 1-6S Li-Po/ Li-Ion /Li-Fe, 1-14 cell Ni-Cd/Ni-MH, 2/6/12V Pb batteries
* Jog dial navigation provides easy navigation of menu
* Built-in temp sensor provides safe charge cut-off option
* Removable power cords allow you to only utilize the power cord you need
* Banana plug inputs provide flexibility when choosing appropriate connector type
* JST balance connector type works with many of today's popular Li-Po batteries (THP and Losi balance adapters available separately)
* 100W Power supply supports extremely powerful charge rates and easily outperforms competing chargers rated at 50 Watts or lower
* 12 bit CPU controller provides precise operation
* Last setting parameter memory
* Reverse and short circuit protection
* Included adapters feature charge outputs for Deans Ultra plugs, Tamiya plugs and Tamiya to receiver & BS style adapters (Deans and Tamiya plugs feature banana output terminals)
* Limited 5-Year Warranty
SPECIFICATION
Input Voltage: 100-240V AC or 12V DC
Batteries: 1-6S Li-Po/ Li-Ion/Li-Fe, 1-10 cell Ni-Cd/Ni-MH, 2/6/12V Pb batteries
Charge Current: 0.1 to 8.0A
Discharge Current: 0.1 to 5.0A
Charging Capacity Cut-off: 100-9900mAh
Charging Mode: Peak (Ni-Cd/Ni-MH), CC/CV (Li-Po/Li-Ion/Li-Fe/Pb)
Trickle Charge Rate: 50-200mA or Off
Output Terminal: Accepts Banana plug
Charge Connector: Deans Ultra Plug, Tamiya style and Tamiya to receiver and BS style adapter
Charge Cutoff: Peak 0-15mV
Temp: 86-140 degrees F
Discharge Cutoff: Adjustable
Safety Timer: 10-720min. or off
http://www.horizonhobby.com/article/2083-dynamite-passport-chargers-review
http://www.dynamiterc.com/ProdInfo/Files/DYN4064-Manual-v2.pdf
PASSPORT ULTRA POWER DC CHARGER
Dynamite's Passport UltraPower 150w DC charger represents the ultimate in versatility and power. With features like 150 watts of charging power (7-Amp charge / 5-Amp discharge rates), 1-5C charge ability, multi-chemistry compatibility and more, the Passport UltraPower 150w DC charger is perfect for intermediate to advanced RC surface enthusiasts, racers as well as air enthusiasts and owners of larger planes and heli's who are looking for a charger that can charge at high C charge rates.
The 150 watt charger provides the ability to charge at 2 and 3C charge rates allowing you to cut your charge times in half or more based upon the batteries charge capabilities. Also included in the array of feature is the Fast Charge Mode which enables the unit to charge batteries approx 35% faster than conventional CC/CV charge cycles. This allows you to hit the track faster instead of waiting around for your batteries to finish charging while your competitors are gaining valuable track time.
The units Storage Mode feature allows you to properly charge your battery to a safe storage voltage in order to safely store your battery(s) while not in use. In addition, and for users with multiple batteries, the unit contains memory for up to 10 unique battery profiles allowing you to simply plug in the battery you want to charge, select the appropriate profile number you designated at the initial charge and begin charging, it's that easy.
The unit requires a separate power supply for running on AC Power. Dynamite's DYN4200 15V DC Power Supply is the perfect compliment for this charger and will provide the optimal amount of power for the unit.
FEATURES
* 7-Amp Charge Rate / 5-Amp Discharge Rate
* 150W Charge Output
* 25W Discharge Power
* Supplied with Tamiya, Traxxas, and Deans Ultra connectors
* Charges 1-26 cells NiCD/NiMH, 1-8 cells Li-Ion/LiPO/LiFe, Pb batteries 2-36V
* Battery Fast Charge Mode (Provides 35% faster charge rates over standard CC/CV charge)
* Store and Load 10 Unique Battery Profiles
* Battery Storage Mode
* Low Input Voltage Protection
* Over Current Protection
* Reverse Polarity Protection
* Over Temperature Protection
* Short Circuit Protection
* Includes software (PC compatible) and USB cable
* Internal Cooling Fan
* Includes Aluminum Carrying Case
SPECIFICATION
Type: DC Multi-Chemistry
Input: 11-18VDC
Number of Cells: 1-8S LiPo, 1-26 Cells NiMH, 2-36V Sealed Lead Acid
Peak: Yes
Current Discharge: Up to 25W (5A)
Charge Rate: 150W (7A)
Input Connector: Banana Jacks
Output Connector: Tamiya, Traxxas, Deans
Battery Type: Lithium Ion, Nickle Metal, Sealed Lead Acid
Cooling Method: Internal Cooling Fan
LCD: Yes
Discharge: Yes
Overload Protection: Yes
DYN4102 PASSPORT ULTRA POWER DC CHARGER
http://www.horizonhobby.com/pdf/DYN4102_FR.pdf
http://www.horizonhobby.co.uk/autoonline/j15dynamite/j15_charger/j15_passport.html
Passport UltraForce 200W AC/DC Charger
Features
* 200W charge power provides enough output power for high capacity batteries with 1-3C charge rates
* Adjustable charge current range of 0.1 to 10.0A
* Charges LiPo/Life (1-6Cells), NiCD/NiMH (1-18 cells) and Pb/SLA type batteries (2-24V)
* Adjustable discharge current range of 0.1 to 5.0A
* Comes with Tamiya, Deans and Traxxas connectors as well as a JST_XH balance adapter
* Integrated 1-6S LiPo balance circuit
* Battery fast charge mode senses the condition of the battery and automatically increases the charge rate for fast charge times
* Battery storage mode senses the condition of the battery and automatically charges it to a reduced capacity for long term storage
* Internal cooling fan
* Low input voltage, over current protection, over temperature, reverse polarity and short circuit protection
* Store and run feature allow the charger to store the previous battery charge setting so the user can quickly begin charging after power up
Power Input: 100-240V AC & 12V DC
Battery Type: Li-Ion/LiPo/LiFe/NiCd/NiMH/Pb
Experience Level: Intermediate
Number of Cells: 1 - 18 Ni-MH 1-6 LiPo
Output Connector: Traxxas
Related Products
Vision LED AC/DC Charger
Vision LCD AC/DC Charger
Vision Ultra AC/DC Charger
Charge Adapter Banana to Deans Male
Charge Adapt Banana: EC3 Female - EC3 DEV
Charge Adapter: Banana to Traxxas Male
Related Articles
Understanding RC Batteries
Get Your Start In RC
Dynamite Passport Chargers Review
http://www.dynamiterc.com/Articles/Article.aspx?ArticleID=2175
http://www.dynamiterc.com/Articles/Article.aspx?ArticleID=2106
http://www.dynamiterc.com/Passport/
