Posté le: 11.02.2011, 07:32:25 Sujet du message: question roulement en sorti de Vilo
bonjour question roulement en sorti de Vilo
avez vous déjà installer ce type de roulement flasqué en sortie de moteur
sa donne quoi ???
607-2TS Bearing 7x19x6 Teflon Sealed
One Ball Bearings , this is a popular size that could be used in many application that uses this size 7mm x 19mm x 6mm. each bearing has 2 Teflon Sealed to protect the bearing from dust or any possible contamination, also bearing is pre-lubricated with grease.
* Item: Double Sealed Ball Bearings
* Type: Deep groove ball bearings
* Dimensions: 7*19*6 mm/Metric
* ID (inner diameter)/Bore=7mm
* OD (outer diameter)=19mm
* Width/Height/thickness=6mm
* Size: 7 x 19 x 6 mm
* Shields: 2 Teflon Seals
* Lubrication: Self Lubricated (Grease)
* Quantity: One Bearing
* Dynamic load rating Cr: 2,600 N
* Static load rating Cor: 1,050 N
* Limiting Speed:
o Grease Lubrication: 40,000 RPM
How can you buy online 607-2TS Bearing 7x19x6 Teflon Sealed
If you have just landed here, this product is offered online by VXB Bearings, www.vxb.com is an online store providing ball bearing at wholesale prices for consumers, you can buy online 607-2TS Bearing 7x19x6 Teflon Sealed, just click on "add to basket" button and then click on the "Checkout" button to buy now the 607-2TS Bearing 7x19x6 Teflon Sealed, the website will lead you to the checkout process (shipping and billing methods), choose one of our 10 shipping methods, they guarantee to meet your needs in terms of time and money, even if you need your 607-2TS Bearing 7x19x6 Teflon Sealed tomorrow morning (aka overnight or next day air) on your desk, 2, 3 days or more, we shall do it. As for preparing your package, we will definately do that before the end of the business day and in most cases we ship on the same day you place your order. Note to international customers, YES, we ship worldwide.
