RCmag :: Voir le sujet - servo Caster Racing C-9849 9kg Metal Geared Analogue Servo
philippe27
MessagePosté le: 08.05.2010, 12:26:21    Sujet du message: servo Caster Racing C-9849 9kg Metal Geared Analogue Servo Répondre en citant
This excellent metal geared servo has excellent torque, precision and speed at an unparalled price for this quality.
Excellent upgrade for any 1/10th and 1/8th steering or throttle application. Offeing excellent torque which will provide you with more positive and controlled steering or a more responsive and better braking car.
These have been tested for months on end prior to release and have proven to be excellent quality.
The case is made from a new plastic blend to offer excellent resistance to warping or braking and uses reenforced lugs on the mounts.
There is no servo on the market which provides this level of performance. There are cheaper servos with the "same" specs but be wary of those that are tested without load on the servo.
Includes -
1 x Double servo Horn - manufactured from ultra high quality plastic - suitable for throtle / brake applications, will not warp unlike many thinner horns
1 x Single servo Horn - manufactured from ultra high quality plastic - suitable for steering applications, will not warp unlike many thinner horns
1 x 4 way servo horn - suitable for applications where you are tight for space and some 1/10th specific mountings.
4 x Rubber moyunting grommets to insulate the servo from knocks and bangs.
6.0v 9.0kg - .10 Secs Transit Time (60degrees)
