Posté le: 09.04.2010, 06:52:57 Sujet du message: Servo Spektrum S6030 et S6040 !
Deux nouveaux servo "surface" chez Spektrum, digitaux, roulements, pignons titane et moteur coreless:
Type: Digital
Application: 1/10 scale monster trucks, buggies and truggies
Torque: 20kg-cm / 278 oz-in @ 6V
Speed: 0.15 sec/60 degrees @ 6V
Length: 40mm
Width: 20mm
Height: 37mm
Weight: 52g / 1.8 oz
Bushing Or Bearing: Bearing
Bearing: Dual
Motor Type: Coreless
Gear Type: Metal
Gear Material: Titanium
Voltage: 4.8 or 6.0V
Type: Digital
Application: 1/10 Scale monster trucks, buggies and truggies
Torque: 12kg-cm / 167 oz-in @ 6V
Speed: 0.08 sec/60 degree @ 6V
Length: 40mm
Width: 20mm
Height: 37mm
Bearing: Dual
Gear Type: Metal
Voltage: 4.8 or 6.0V _________________ Papy boomer
Elle est pas belle la vie.
