RCmag :: Voir le sujet - Nouveaux inserts de pincement pour RC8 !
MessagePosté le: 06.04.2010, 09:58:20    Sujet du message: Nouveaux inserts de pincement pour RC8 ! Répondre en citant
Pour effectuer un règlage de pincement au demi degré près Mad
Adjust your RC8B or RC8T CE rear toe-in to 2.5° or 3.5° per side with the new #89045 RC8 half-degree toe bushings.
• CNC-machined plastic
• For use with #89463 RC8B aluminum D-plate
• Use indicator arrow on back of bushing: When arrow points to center of car = 2.5° toe. When arrow points to outside of car = 3.5° toe.
• Hinge pin hole is 0.5mm offset from 1-dot bushing. Can be used anywhere on the car for more fine adjustments
• 4 bushings per package
