*Brake System Base by
Alum Milling
Most ofbrake system
base are made by
plastic material which
without flexible character;
but our brake system base is made by alum milling with high strength and
lexible character to improve the life time and enhance the brake power.
* Environment friendly Brake Pad by Specific Individual Material
1, Enlarged the outer diameter for better brake power
which increasing 1/3 contact area.
2, Improve 40% brake power which make life 3 times longer.
*Brake Disc with vent design
The brake dick will create the high
temperature during the high speed
driving, also absorb the dusty air which
caused the brake power loose.
Therefore, vent design brake disc
can efficient improve the cooling and
