RCmag :: Voir le sujet - Differentes Pieces Option alu pour RC8
philippe27
MessagePosté le: 25.03.2009, 14:30:47    Sujet du message: Differentes Pieces Option alu pour RC8 Répondre en citant
pièces options en alu pour RC8
existe en 2 colories Titanium et Copper
Product ID: 2396
Aluminum Bell Crank (Titanium) The item bar code is 841149023969
Product ID: 2395 Aluminum Bell Crank (Copper)
The item bar code is 841149023952
Product ID: 2473 Aluminum Top Plate Upper/Lower (Titanium)
The item bar code is 841149024737
Product ID: 2474 Aluminum Front Arm Mount (Copper).
.The item bar code is 841149024744
Product ID: 2477 Aluminum Rear Arm Mount (Titanium).
The item bar code is 841149024775
Product ID: 2497
Aluminum Fuel Tank Mount (Copper) The item bar
code is 841149024973
a voir au niveau qualité !!!!
ils font beaucoup de pièces options pour différentes marques et models d'engins roulants
voir leur site
http://www.ghhobby.com/categories.php
philippe27
MessagePosté le: 11.04.2009, 08:23:12    Sujet du message: commes dit le team asso les pieces on un look sexy Répondre en citant
CNC Machined Parts!
Factory Team's all-new CNC machined rear hub carriers add strength, precision, added adjustability, and sexy looks to the RC8 series of Team Associated vehicles. Precision CNC machined from quality 7075 aluminum, these parts are a direct fit for the RC8, RC8-RS, RC8T, RC8T-RS, and all SC8 models.
Parts are durable, lightweight, and maintain the suspension geometry optimized by the RC8 design team. However, a new camber link position has been added to the rear hub carriers for added adjustability. Factory driver Ryan Maifield has been using this new link position to increase steering on high-grip track surfaces.
These parts come conveniently packaged in pairs and feature Team Associated's signature blue anodizing with sexy-look second-op machining.
CNC Machined Parts!
Factory Team's all-new CNC machined steering blocks add strength, precision, added adjustability, and sexy looks to the RC8 series of Team Associated vehicles. Precision CNC machined from quality 7075 aluminum, these parts are a direct fit for the RC8, RC8-RS, RC8T, RC8T-RS, and all SC8 models.
These parts are durable, lightweight, and maintain the suspension geometry optimized by the RC8 design team. These parts come conveniently packaged in pairs and feature Team Associated's signature blue anodizing with sexy-look second-op machining.
Sylveris
MessagePosté le: 12.10.2009, 23:05:15    Sujet du message: Répondre en citant
Pour ceux qui veulent gagner un peu de poids partout, je vous post mon humble expérience avec une voiture qui n'a jamais subi de choc, ou cassé quoi que ce soit pour l'instant, peut-être la chance.
Si vous voulez des pièces alus, je ne vous recommande pas les plots de sauve servo alu King Headz, certes la différence de poids est énorme à la pièce : 2.45g contre 6.74 , mais finalement à peine 10g d'économie en tout...
Dans un run, j'ai trouvé quelque chose de bizarre dans ma "tringlerie" de direction : plot de sauve servo droit cassé, et en fait ce n'est pas illogique, c'est très fin ! Alors attention fragile !
Bye !
Options SYLVERIS RC :
www.sylveris-rc.fr
flo973
MessagePosté le: 12.10.2009, 23:22:41    Sujet du message: pieces alu Répondre en citant
bonjour
ou est ce que peu trouve s est pièces alu rc 8
bibi49
MessagePosté le: 13.10.2009, 07:42:16    Sujet du message: Répondre en citant
PP a longtemps tourné avec ces plots de Sauve-servos KH sans soucis que je sache...
sinon, pour trouver ce type d'options, c'est le VPC aux USA. En france, tu trouves déjà de très belles options Fiorini, les options Asso (via MRC).
