RCmag :: Voir le sujet - Pieces option MBX6 kingheads
philippe27
MessagePosté le: 31.03.2009, 16:45:20    Sujet du message: Pieces option MBX6 kingheads Répondre en citant
Fits: Mugen MBX6
FEATURES: This holder block is CNC machined from
7075 aircraft grade aluminum and is Black Anodized. These
are designed to increase rigidity and add strength.
INCLUDES:
(1) Front Upper Adjustable Suspension Arm
SPECS.
Weight: 6.64 grams
FEATURES: This Upper Steering Plate is CNC machined
from 7075 aircraft grade aluminum and Black Anodized.
These are designed to increase rigidity and add strength.
INCLUDES:
(1) Upper Steering Plate
SPECS.
Material: 7075 Aircraft Billet Aluminum
Thickness: 4.57MM (.180")
Weight: 7.52 grams
FEATURES: This Mount is CNC machined from
7075 aircraft grade aluminum and Anodized. These are designed
with a base mount and removable top blocks. Once the mount is installed
in the vehicle and the gear mesh is set you can remove and reinstall the
motor without resetting the mesh. This mount has an extended leg that
will help to reduce chassis flex near the flywheel hole.
This mount will fit either a Nova based or Picco based motors, no need to order different mounts for different motors.
Extra top block sets can be purchased separately so that other motors
can be swapped out quickly.
++ Mount can not be used with Roto or Pull start motors ++
INCLUDES:
(1) Base Mount
(1) Set of top blocks
(4) M3 x 14MM Alloy Allen Head Screws (mounts top blocks to base)
(4) M3 lock washers (used with M3 x 14MM screws)
(4) M3 x 10MM Alloy Allen Head Screws (mounts motor to top blocks)
SPECS.
Weight: 31.15 grams (base and 2 top blocks - no hardware)
INCLUDES:
(1) Base Mount
SPECS.
Weight: 27.75 grams (base and 2 top blocks - no hardware)
FEATURES: This is a set of extra top blocks for the Mugen MBX6
EZ Change Motor Mount.
These top blocks are CNC machined from 7075 aircraft grade
aluminum and Anodized black.
INCLUDES:
(2) Motor Mount Top Blocks
SPECS.
Weight: 4.58 grams (Each Block)
FEATURES: This Center Diff Top Plate is CNC machined
from 7075 aircraft grade aluminum and is Black Anodized.
Plastic bushing are replaced with ball bearings for smoother
braking action.
INCLUDES:
(1) Center Diff Top Plate
(2) 5mm x 9mm x 3mm Flanged Bearings
SPECS.
Weight: 4.60 grams (without bearings)
FEATURES: These Radio Tray Mount Blocks are CNC machined
from 7075 aircraft grade aluminum and are Black Anodized.
INCLUDES:
(2) Mount Blocks
SPECS.
Weight: 4.90 grams (each block)
FEATURES: This Front Torque Arm is CNC machined from
The brace has pockets to capture the factory lock nuts.
INCLUDES:
(1) Torque Arm
SPECS.
Thickness: 5MM (.296")
Weight: 9.04 grams
blade98000
MessagePosté le: 31.03.2009, 16:48:29    Sujet du message: Répondre en citant
j ai pris le support monobloc
je vous tiendrai au courant mais de probleme sur la qualite je connais c est vraiment le top
