philippe27 Champion du monde
Posté le: 07.04.2018, 17:54:30 Sujet du message: |
Descripción
RC Car Setup 1/8 TT now for mobiles! with this app you can save the setup you use in each track, and share it!.
The data you can save is divided into four sections: Race Info, Oils, Front Suspension and Rear Suspension.
Race Info data:
- Event
- Driver
- Car
- Radio
- Servos
- Engine
- Fuel
- Glow plug
- Clutch
- Gearing
- Tyres
- Best time
- Photo
- Notes
Oils data:
- Preload (front and rear shocks)
- Spring color (front and rear shocks)
- Oil (front and rear shocks)
- Piston holes (front and rear shocks)
- Hole size (front and rear shocks)
- Rebound (front and rear shocks)
- Oil (front, center and rear diff)
Suspension data:
- Shock position (front and rear suspension)
- Upper link position (front and rear suspension)
- Lower arm position (front and rear suspension)
- Ackerman (front suspension)
- Upper link spacers (front suspension)
- Ride height (front and rear suspension)
- Camber (front and rear suspension)
- Caster (front and rear suspension)
- Toe (front and rear suspension)
- Sway bar (front and rear suspension)
- Wheel hex (front and rear suspension)
- Balanced weight (front and rear suspension)
- Wing (rear suspension)
Novedades
Historial de actualizaciones
28 de mar. de 2018 Versión 1.2
- With this new version you can select the model and make of your car, there are more than 20 different models available.
- New graphs of the suspension setup, easier to understand. With front, top and rear views.
Make and models available:
- Agama -> 215, 215SV, A8EVO
- Associated -> RC8 B3, RC8 3.1
- Durango -> DNX8
- HB Racing -> D817, D817V2
- Hobao -> Hyper VS, Hyper 9
- Hong Nor -> X3 Sabre, X3 Sabre Evo3.0
- JQ -> The Car 2017, The Car 2015/16
- Kyosho -> MP9, MP9 TKI3, MP9 TKI4
- Mugen Seiki -> MBX7, MBX8
- Serpent -> Cobra 2.2, Cobra SRX8 Evo
- Sworkz -> S350 EvoII, S35-3
- Tekno -> NB-48.3, NB-48.4
- TLR -> 8ight 3.0, 8ight 4.0
- Xray -> XB8´17, XB8´18
Información
Desarrollador Jose Antonio Garcia Mancebo
Tamaño 20.6 MB
Categoría Deportes
Compatibilidad
Requiere iOS 11.1 o posterior. Compatible con iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone SE, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, iPad mini 4 Wi-Fi + Cellular, iPad Pro de 12,9", iPad Pro de 12,9" Wi-Fi + Cellular, iPad Pro de 9,7", iPad Pro de 9,7" Wi-Fi + Cellular, iPad (quinta generación), iPad Wi-Fi + Cellular (quinta generación), iPad Pro de 12,9" (segunda generación), iPad Pro de 12,9" Wi‑Fi + Cellular (segunda generación), iPad Pro de 10,5", iPad Pro de 10,5" Wi‑Fi + Cellular y iPod touch.
Idiomas
Inglés
Edad Clasificada 4+
Copyright © 2017 GarManApp
Precio 2,29 € |
