Posté le: 06.12.2017, 14:47:57 Sujet du message: Nouveaux servo Team Tekin.
T-120 Lo-Pro Speed with aluminum Vector 20mm arm
T-180 Lo-Pro Torque with aluminum Vector 20mm arm
T-130 Speed with aluminum Vector 20mm arm
T-190 Torque with aluminum Vector 20mm arm
T-250 Speed with aluminum Crowbar clamping-type 20mm arm
T-300 Torque with aluminum Vector 20mm arm
T-360 Torque with aluminum Crowbar clamping-type 20mm arm
T-440 Torque with aluminum Crowbar clamping-type 20mm arm
– Specifically Designed for 1/10 and 1/8 Scale Applications
– Included Aluminum 20mm Crowbar HD Clamp Servo Arm
– Full Aluminum Servo Housing
– Element Proof Design
– Precision Cut Full Metal Gears
– ABEC5 Ball Bearings
– Digital Magnetic Position Encoder
– High Voltage Capable
– High Torque Coreless Motor
– 25T Output Spline
– Overload Protection Technology
– Thermal Protection Circuitry
– Low Voltage Alarm**
– Quiet, Efficient, Cool Operation
– HDAC: High Density Copper PCB’s
HOTWIRE™ programmable features:
– Feel – Mild to Aggressive
– Speed Limit
– Torque (0-100%)
– Torque Delay
– Direction – Normal / Reverse
– Center Point
– Travel
– Soft Starting Speed & Torque
– Max Temp Alarm
– Low Voltage Alarm
– Over Voltage Alarm
– Bind Relief
– Fail Safe Speed and Position
– Set Custom Servo Name
Toutes les caractéristiques servo sur TeamTekinServo _________________ Papy boomer
Une marque historique de la RC _________________ rcmag.com pour le forum, les photos et vidéos
