RCmag :: Voir le sujet - Chassis Focus – Yukinori Kagayama 1/10 elect
philippe27
MessagePosté le: 20.02.2017, 16:33:03    Sujet du message: Chassis Focus – Yukinori Kagayama 1/10 elect Répondre en citant
[img]Chassis – Spice BD7 Single Belt Conversion
Motor – Scorpion 17.5T
ESC – Hobbywing
Battery – G Style 6000mAh
Tires (handout) – Ride
Radio/Servo – Sanwa
Body – Tamiya
Remarks – Spice designer Yukinori Kagayama is running his own designed single belt conversion for the Yokomo BD7. Suitable for up to 10.5 turn non boost or 13.5 turn boost touring car, the single belt design, which replaces the original 2 belt configuration, gives the car a more linear feel on both throttle and brake due to the lack of slack in the belts. The conversion itself comprises of the single piece motor mount and belt tensioner, the tope deck and the single belt. An updated version soon to be released will allow the motor mount position to be adjusted and with a single belt design there is no need to different belts for each motor position.
